bench to buckets
Discussion in 'Interior/Electronics' started by eab92, Jun 10, 2008.
  1. eab92
    eab92 Newbie
    95 hilux 4x4
    I recently bought a '94 4wd regular cab. It has a gray bench seat. A friend sold me a set of gray SR5 buckets that came out of an '87. How difficult will it be to make the switch? Also, I'm missing 2 of the knobs and the recline & release handle for the drivers seat if anybody has some to sell.
  2. MiniSimp
    MiniSimp Member
    Tracy, Ca
    Um....unbolt bench, bolt up buckets. That's about it.
    You will need 4 more bolts.
  3. eab92
    eab92 Newbie
    95 hilux 4x4
    There's no holes to drill, no brackets to modify or anything?
  4. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    Remember there maybe a nut missing, for both the passenger and driver's seat where the tranny hump is. Not all 94's have this bolt welded in to the underside of the floor, mine didn't. Other than that, it's a simple swap!! :D
  5. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    IDK how hard the swap is but today or tommorow im getting some 86 ford ranger bucket seats installed. they are sweet. they sit on the floor, recline, slide and everything. here they are.. I got to get a seat cover cuz they are red though.
  6. eab92
    eab92 Newbie
    95 hilux 4x4
    One last question, what about the seatbelts? Where do they bolt up?
  7. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    Same place they were before, the 2 bolts in the back.
  8. eab92
    eab92 Newbie
    95 hilux 4x4
    Thanks, I really appreciate the knowledge. All I need now is the handle and the knobs for the drivers seat. Thanks again!
  9. ChOpPeD~N~DROPped
    ChOpPeD~N~DROPped Enthusiast
    West of Atlanta!
    94 Extended cab
    mine had a 60/40 split bench in it and when I put my 4runner seats in I had to modify the bracket on the drivers seat nearest the tranny tunnel. I drilled a hole in a piece of flat steel and welded it onto the existing bracket and it worked out very well. as far as seat belts if you didn't have the holes for them already in your truck you could just get a longer bolt and bolt it down with the seat bracket.
  10. east1la
    east1la Enthusiast
    nc
    1993 toyota pickup dually
    about the missing nut, is there anything it can be done about it?? I just got a set of bucket seats for mine from junkyard. they need to be redone. I just need some good ideas.
  11. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    You will need to cut into the channel from underneath, and either weld a nut in place or with help just hold the nut there while someone tightens the bolt.
    There is a thread out there on doing this, I just can't remember if it was here or yotatech or yoda scene.
    I was in a hurry to get mine in, I have only 3 bolts for each seat to hold them down. Got to get that fixed one of these days :rolleyes:
