A/C Problems
Discussion in 'Maintenance/Repair' started by TOY|STORY808, Apr 17, 2010.
  1. TOY|STORY808
    TOY|STORY808 Enthusiast
    WAIPAHU TO LAS VEGAS
    1985 TOYOTA PICK UP
    I tried to recharge my friends a/c system.
    i noticed that the a/c clutch didnt engage.
    i checked to see if there was power going to the a/c compressor
    and there was no power.
    but the funny thing is that the a/c switch light turns on.
    im guessing it might be the a/c amplifier
    what do you guys think??
    thanks in advance
  2. NotAvailable
    NotAvailable Addict
    im having the same problem. but try run power and ground to the ac compressor itself and see if it engages..i forget the tool that i used to do that but looks like a multimeter. i did that and my stuff turned on so i traced wires back to the cab n found it rubbing on some edges and the ground was bad and the power wire was kinda questionable and the connection behind the button was dirty to but idk...just my input good luck
  3. toy_boy
    toy_boy Addict
    California
    1979 Toyota 4x4
    I've had this happen before on other vehicles I've owned. Just because the light comes on doesn't necessarily mean the compressor is actually working. Check all your fuses, relays, and wiring - assuming the compressor itself checks out.
  4. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Put power to the wire going to the compresor with a jumper wire just to check if the clutch engages. If it engages, your comp should be ok. Could be a bad relay. Also, when your charging the ac, the clutch wont engage unless you have enough pressure in the system.
  5. TOY|STORY808
    1985 TOYOTA PICK UP
    yea i know it wont engage unless it has enough pressure.
    the gauge read 35 psi when i noticed that the compressor didnt engage was like ****
    something else is the problem
    but ill checck to see if jumping the compressor helps.
    thanks for info guys
    ill keep you guys updated if i find the problem or what not..
  6. frknlo87
    frknlo87 Member
    Waipahu, HI
    1989 Ex-Cab , 1991 Single
    sounds like the resistor or relay. If you have pressure in the line sound engauge when the button is on. You can change the ac button itself because im like 80% sure that the resistor is in the button itself.
