Anyone own a 4 speed base model truck with a 8" rear?
Discussion in 'Suspension/Chassis' started by JamesD, Apr 10, 2010.
  1. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    I need your VIN# for parts look up. It has to come with a 4 speed manual trans or a single wheel rear 1 ton truck. These trucks had the 8" 4WD third members and 30 spline axles and were 5 lug.
    Thanks, James
  2. Angel
    Angel Member
    Orlando
    83 pick up
    4wd or 2wd
  3. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    Sorry 2WD.
    James
  4. goingnowherefast
    goingnowherefast Enthusiast
    Haddam CT
    1965 Stout
    I have a vin for an 87 single wheel 1 ton.although it came with a w56 5spd.If it would help I can send you a pm.let me know if it fits you needs.
  5. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    u got a pm..well in a few u will have it.
  6. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    The 4 speed 2wd 8" third member is not the same as a 4wd's. The 2wd came with 307 gears so the carrier housing had to be offset because of the massive pinion size. If you plan on changing to a 4 speed 5 lug and plan on changing the ratio to standard or lower ratioes you will need a 4wd carrier housing because the ring gear wont fit.:waytogo:
  7. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    :waytogo: Taking the 1 ton plunge?
  8. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    I'm not following you. Do you mean that the axle shafts would be two different lengths?
  9. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    Did it come with an 8" rear? If the answer is yes then send me a PM.
    Thanks, James
  10. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    No. What I'm trying to do is use the 2wd 8" rear housing and axles and use the 4wd third members for different gear ratios since they are stronger than the 27 spline 7.5" rears that we have in our 2wd Toyotas.
    James
  11. Raffaelli
    Houston
    82 Longbed 2WD
    :D Thats what I ment. I got a 8in 5 Lug dually rear with a 4cyl 4wd Diff in it.
    Its really tough lookin. The axle shafts have the girth! I still need a Lsd/locker.
    I think EVOL ment that you cant put 4wd R&P gears into a 8in 3.07 pumkin. But who would want to do that. Just get another diff outa a 4wd.
  12. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    The dually axle is a full floater and is totally different. This is why I'm looking for a VIN# so I can go to my local Toyota dealer and see what parts are different and what parts are the same.
    James
  13. IronNam
    some 2wd trucks have 8"
    some 2wd trucks have 7.5"
  14. jetas
    mine's a 8":drool:
  15. IronNam
    lucky you....
  16. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    You have the V6 which I forgot they came with the 8" as well.
    James
  17. Blacklightnin55
    Blacklightnin55 Member
    Louisiana
    1990 Ext-cab
  18. goingnowherefast
    Haddam CT
    1965 Stout
    You have PM.Good Luck!
  19. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    ill give u my vin after work i have a 4speed with a 8" rear end the v6 and i4 8" is diff though the v6 u can do the Supra lsd swap w/o major mods the i4 requires more work... better off using the v6 8" if u are going this route
  20. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    I know about the diffs but another member here says the 8" housings for the 2wd will not accept 4wd 8" diffs because there is not enough depth on the 2wd 8" housings or something like that.
    Thanks, James
