Need help asap!
Discussion in 'Suspension/Chassis' started by jrknsrk08, Apr 9, 2010.
  1. jrknsrk08
    jrknsrk08 Member
    Sierra Madre, CA
    88 single cab 2wd
    I am looking into getting this truck. its a 83 toyota pickup 4x4. looking to finish up a rock crawler project someone didnt have time to complete. 83's came with solid axel front and rear? I will attach photos and any help on the photos would be great before I make the trip to see this in person. Not sure what I am getting into.
  2. SD YOTA
    keep in mind when you look into getting someone's unfinished project..... you could be getting into something you will be starting from ground one. since it was somoeone elses ideas and thought process, it may differ from your view on how something should be built.
    look it over.......... look it over well........ and look it over again. be sure you are willing to take it on. from what i can see, it has a standard lift and a cage that was in process of being built. beyond that, if it starts up, runs, drives well, and the price is right, i say it "looks" like a fairly good start to a crawler.
  3. dillinja666
    so....what do you want to know? i cant really tell from the pics if its junk or not, but i can see someone went nutty with the axle trussels and pumpkin savers...whats going on suspension wise? the first pic its hard to tell whats straps on the trailer and whats link bars/leafs
  4. jrknsrk08
    jrknsrk08 Member
    Sierra Madre, CA
    88 single cab 2wd
    he is asking $2000 obo. The engine was just rebuilt runs strong. suspension wise I would be starting from ground zero. Does a stock 83 toyota 4x4 run solid axels front and rear though?
  5. EFnetOper
    EFnetOper Veteran
    Eagle, WI
    94 2wd Pickup
    I believe anything 4wheel drive 85 and older is solid front axle.
  6. jrknsrk08
    jrknsrk08 Member
    Sierra Madre, CA
    88 single cab 2wd
    thanks
  7. drewp
    drewp Member
    well it appears to have stock steering (j arms break alot), exo is hideous and find out if he used dom,hrew, chromoly etc, has it been geared in the diffs, dual cases or not, lockers?, front axle rebuilt, stock or broken birfs?, w56 tranny or not etc etc, i wouldnt ever pay more than 2000 grand for something like that, id try and ween him down to 1500,
  8. dillinja666
    sounds like you are paying 2 grand for 2 axels, a trans and a motor...not worth it..1000 max...
