35"s gearing help
Discussion in 'Engine/Drivetrain' started by planemos, Mar 10, 2010.
  1. planemos
    planemos Toyotaholic
    British Columbia
    Does anyone know what gear ratio I need to run 35"s on my '88? It is a 22RE and quite an old truck so I want to be easy on it. I am more of a lowered guy so I don't know off the top of my head.:confused:
  2. FOKAI
    FOKAI Veteran
    SD
    84 truck, 05 4Runner
    If you want to help out that little 4 cylinder then 5.29's. I currently have 5.29's on my 84 and ran 35's for a few months. I was able to use 5th gear. Cruising speed of 70mph my rpm was at 3000.
  3. tenfourtyeight
    tenfourtyeight Member
    Vista, Ca
    94 single cab; 91 4wd extra cab; 74 Hilux
    Fokai is right- definitely run 5:29 with a 22RE.
  4. SD YOTA
    i second that 5:29's are suggested for 35's. if you see yourself however changing back down to 33's i would go 4:88's.
  5. 22r
    22r Veteran
    Maui
    lol we installed 529's in my buddys 85 4runner with only 31 inch tires. hahah first gear is like nadden now. haha
