Door will not open help
Discussion in 'Exterior/Body' started by krazyasslunatic, Mar 9, 2010.
  1. krazyasslunatic
    krazyasslunatic Enthusiast
    Oklahoma
    1971 Hilux
    Okay, i just bought this truck and was told the passenger door didnt open. I figured it be an easy fix so do worry about it. I have an appointment to get a radio and some speakers installed and it just hit me that he may need the door to open. I took the door panel off and i cant figure it out. The interior handle seems like it works fine, like its connected to whatever it suppose to be connected to, cant see in there very well to tell for sure. The exterior door handle doesnt move at all, like if i lift up the handle it doesnt budge, any advise?
  2. butterscotch baller
    butterscotch baller Member
    Draper, Utah
    1976 Hilux
    open it from the inside? or is the door actually jammed?
  3. krazyasslunatic
    Oklahoma
    1971 Hilux
    not wont open either way
  4. dillinja666
    follow the rod with your hand, it should connect to the door lock somewhere, then grab the lock tab thing and pull it, it should pivot and engauge the piece of the lock that the handle rod connects to, it its not ( and thats usually why they wont open ) pull the door handle rod, and pull up on that pivot. I wish i had a picture for ya but we dont have one of those in the shop right now...
  5. krazyasslunatic
    Oklahoma
    1971 Hilux
    the exterior door handle is jammed, it doesnt move at all, i took the panel off and just cant figure it out. When i get a day off im gonna do take a door from a junkyard so i have a parts door and something to compare it to
  6. trap
    trap Addict
    orange county ca
    92 pickup
    As a installer, I would be extremely pissed at you if you brought me a truck with a door that didn't open... on that note, I would see if he wants to mess with it. Any installer worth a damn should be able to get that door open and tell whats broken in less then 5 minutes if you have the panel off.
  7. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    if you can reach your hand in there with the panel off from the inside, feel for the latch, don't worry about the rod connecting to it...your gonna have to push down on the actual latch not the rod
  8. krazyasslunatic
    Oklahoma
    1971 Hilux
    I went and told him before hand that my door did not open, the stock speaker wires are right there anyways and they mount over the door panels so it should be fine
  9. krazyasslunatic
    Oklahoma
    1971 Hilux
    Really wish I knew what you were talking about
  10. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    93-2wd 2.5/3drop, 87-4wd22RTE, 06GTOls2, 08FJCruiserTT(Daily)
    why don't you just take the other door panel off and compare them... it's a mirror image of the broken one...
  11. krazyasslunatic
    Oklahoma
    1971 Hilux
    Yeah i know but i dont want to rip up the tabs that pin the panel to the door
