Sloppy Shifter
Discussion in 'Maintenance/Repair' started by Badlux, May 6, 2008.
  1. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Is there a bushing or some way that I could tighten up my shifter? It shifts ok but its kind loose and sloppy feeling.
  2. valreyjae
    valreyjae Newbie
    85 22rec xcab
    shifter
    theres a plastic bushing and the bottom of the shifter, most likely held in by snap rings, its about 10 bucks at the dealership
    i read this on an eairlier post from ateam20x dated 7/9/2007
    let me know if it works
  3. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
  4. 1989minitoy
    1989minitoy Member
    oroville
    89 mini toy
    lol ya i was gonna suggest the same... hey u might just have to get under there and take a look, my top cap is loose...
  5. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Huh???
  6. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    at the bottum part or the site on marlincrawler thats the white looking thing thats what you need to replace. what year is your truck ? some trannys you just PUSH and turn the LOCK and and the stick shift will pop out. on some other years there are bolts(not sure though cant remember) tell me your year?
  7. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    I know thats what I need to replace, just trying to figure out what trans I have. Its a 87 xtra cab. I have been reading that there is some kind of ring that needs to be removed in order to pull the shifter out. Correct me if I'm wrong. Maybe I'll try giving them a call tomorrow.
  8. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    93-2wd 2.5/3drop, 87-4wd22RTE, 06GTOls2, 08FJCruiserTT(Daily)
    Check out this page and you should be able to figure out your tranny...
    http://www.brian894x4.com/Gearratiosanddiffs.html
    The shifter comes out by pushing in/down on a retaining ring/collar around it's base... you have to push the ring/collar in enough to turn it and then it pops up releasing the shifter. They all have bolts around the base of the shifter but they do not need to be removed to remove your shifter, the ring/collar has a spring under it that keeps it locked in place, thats why you have to push it in/down and turn to release.
    The Marlin replacement part is much better than the original, stronger and is designed to be installed from the top. definately your best bet!!!
  9. grounds671
    grounds671 Veteran
    tampa
    1995 pickup std
    What MTB said is exactly how your model is. very very easy. you dont even have crawl under everything is from the top!
  10. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Its been awhile but I finally changed my shifter bushing. I ended up just buying the one from the dealer.
    my shifter was very easy to remove. No pushing or twisting. I had the one with the four screws.
    Heres the new bushing. As you can see the old one on the left is missing half the bushing.
    Its also a good idea to replace the piece on the bottom. My old one was really worn out.
  11. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    My shifter came off by unbolting the four screws. From my understanding, some shifters have to be pushed down and turned to be remove.
    New bushing installed.
  12. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Probably didn't need to do this or I should have used gear oil but I put some grease on it before I reinstalled it. I had to do some cleaning because some of the old bushing was stuck on the ball thingy.
    And here it is installed. Now my shifter is as tight as a........new shifter:)
