headlights???
Discussion in '1976-1983 Build-Up/Project Threads' started by white93turbotruck, Feb 13, 2010.
  1. white93turbotruck
    white93turbotruck Enthusiast
    do they make a hid kit for the 1973-1978 toyota pickup.or even some h4 headlights and where would you buy them???
  2. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    I would like to know as well but for the 89 and up.
  3. 73TRD
    73TRD Veteran
    Redding, CA
    84 sr5 standard cab short bed, 73 hilux short bed
    hella makes H4 cases for both styles. the cheapest i found were on summit. i heard that all the other cases are crap
  4. white93turbotruck
    thanks i look there!!!
  5. 73TRD
    73TRD Veteran
    Redding, CA
    if you cant find them there, go to thefind.com. its a search engine for shopping and thats where i find all my parts
  6. standardbyker88
    always get my h4 housings on ebay. an hid kit is basically a better bulb system for the H4 style socket. in my 78 i found a seller on ebay with nice quality housings and bulbs for the 5-3/4" rounds. i did have to trim my core support openings at the back a bit though since they are alot deeper. also had to split the hold down ring for the slightly larger diameter (about 1/8" more) and cut off the alignment ears. i also plan to grind down a little of the meat where it sits at the flange so its flat not a little off. nice looking product and good performance, just a little work to make them fit. no "city lights" hold though. although i may put some. they also had them available with a blue halo ring, which although their photos decieve you into thinking is always blue, is actually clear until it lights up. they sent me one of them by mistake instead of a normal when i needed a replacement.
    im also using some 95/110w or 85/90w 2 way bulbs, but with stock wiring. i have them aligned for m highs to be a nice low pattern. i plan to rewire the lights to utilize the centers now having low beam function and to run power off relays and larger wire to drastically lessen the voltage drop they get. doing that lets the bulbs get 12-13v at idle instead of about 9-10. i dont have their ebay name off hand but can look and find it.
  7. white93turbotruck
    i noticed your headlights in the combinations??? fourm thanks!!!
  8. TRUCK ACTION
    True HID are not just a bulb change.
    High quality glass lens ,ballast,harness, & bulb.
    With output ranges from 3,000k-30,000k
    Some of the kits are low beam only,the better ones high & low beams.Also different shades of light.
    Hella are the best lens.
    Here's a site with a good kit for Toyota trucks
    www,hidenonlights.com
    :cool:
  9. six7one_KDR
    six7one_KDR Veteran
    From Thee Island of GUAM,Live's in WASHINGTON / NO
    1976,1979,and also YES a 1973 HILUX
    H.i.d izzel's
    YUP,THATS WHAT IM RUNNING UP FRONT ON MY 79 RIGHT NOW,THERE THE 7" ROUND HELLA'S WITH XENON H.I.DIZZEL'S "6000K'S" ON THEM.MAKE SURE YOU GET THE ONE'S WITH THE GLASS HOUSING.BETTER LITING THEN THE PLASTIK ONE'S.:waytogo:
      File size:
      135.5 KB
      65
