Heads!
Discussion in 'Engine/Drivetrain' started by l0wlux, Feb 11, 2010.
  1. l0wlux
    l0wlux Member
    can a head from a 86 22r fit on a 84 block without problems??
    also if the head form the 86 is clean but not resurfaced can i put it on the 84 block if both is clean??? like do i need to have it resurfaced??
  2. Nook
    Nook Addict
    oregon
    If the 84 block is a pre laser block, NO, they won't interchange, early 22R's were a tall block, tall head configuration, used a 98 link timing chain, in around late 84 they changed the engines to a short block, short head setup and used a 96 link chain, so they won't swap without major machine work.
    As for bolting a head on without surfacing, yes thats fine if the surface is flat, clean, and free of any dings, dents, gouges, scratches, or anything else that might hamper gasket sealing.
  3. l0wlux
    l0wlux Member
    so are you saying i cant put the head on top the block in my truck??
  4. l0wlux
    l0wlux Member
    also i have a block on the side that i dont know what year it came out of is there anyway i can find out??
  5. standardbyker88
    someone will chime in with how to tell which 22r block you have. if its the newer one it should work fine. older one, not a direct bolt on. 84 was a change year, so they have both types. and i second the surfacing info. it both look perfectly clean then you should be okay.
  6. Nook
    Nook Addict
    oregon
    Go to the link below and look at the block picture at the bottom, if your 84? block has the laser boss on the drivers side, then yes you can use the 86 head on your engine, if not, no.. Same deal, if the extra block you have has the boss, then its a late model short deck block, if not its an earlier tall deck engine.
    http://www.lcengineering.com/TechNotes/TechNote49.htm
  7. l0wlux
    l0wlux Member
    looks like the motor in my truck is laser cut.
    so that means a 86 head will bolt up to it right??
  8. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    yes, if its the laser cut or the later 22r block, the 86 head will bolt on to it...
  9. l0wlux
    l0wlux Member
    right on thanks everyone for the help....
    i really wannah get my truck running again
  10. theghiaisred
    theghiaisred Newbie
    Carrollton, Ohio U.S.A.
    87 RN50 2wd 22r, 87 4Runner 22re
    If your engine has the dome top pistons like a pre-85 engine has the there is no way that a post-85 laser block head will work, you will crash the pistons into the head.
