What is leaking here?
Discussion in 'Maintenance/Repair' started by joeynational, Feb 9, 2010.
  1. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    I've had this leak for a while, and now i want to fix it...at first i thought it was leaking from the back reservoir grommet, but now it looks like its leaking from the back? what do you guys think? should i buy a rebuild kit or a new MC? If i buy a new MC i'm going OEM, this is my 3rd MC!!
  2. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    I only buy OEM master cylinders, especially for something as critical as the brakes. I've also had enough bad experiences with cheap rebuilt aftermarket units to learn my lessonn.
  3. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    id take the 4 bolts off to unbolt the master (you can do it without touching the lines) and pull it out enuff to make sure the cylinder is actually holding pressure and not leaking out its a$$ into your booster.
    if thats not it, you either have a nut at the bottom of the resivour or some other way to tighten it down, or the O ring is bad.
  4. TRUCK ACTION
    Get a new one!:cool:
  5. standardbyker88
    my 78 leaked into the booster to the point that it filled it, then drained onto my feet. lol. so i put a fresh condition looking one from a junkyard 81. master and booster. but, yes, if they are leaking from the cups tighten the nut or put an O ring in the base.
  6. joeynational
    PHX,AZ
    91 2WD
    the screw is tightened all the way, the reservoir has grommets that i have only found at the dealer..like 8$ each! i'm gonig to take off the MC today and see if its leaking into the booster
  7. joeynational
    PHX,AZ
    91 2WD
    just pulled it off, leaking like a mofo, time for a new one i guess..the seal looks to be grooved too
  8. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    that seal is for vacuum not fluid.
    there is a O ring inside the master with a snap ring on top, prolly had a bad rebuilt one.
    if you still have the OEM master its better to hone it and rebuild it, then get a refurb.
  9. joeynational
    PHX,AZ
    91 2WD
    ahhh I do have a vacuum leak that i never found, so thats probably it!! THX!!
    i'm going to get a brand new OEM one this time..i heard the metal is too thin to hone them out..Does anyone know which part# or model pickup to get one from that has the 1" bore? I believe mine is the smaller version either 3/4 or 15/16
  10. joeynational
    PHX,AZ
    91 2WD
    getting ready to buy a new MC this is the cheapest i have found for OEM Aisin, but there are two different MCs here that are coming up for my truck, I tried looking up the part# to check the bore size and had no luck, contacted the seller and they do not know, I can't tell what the difference is here except one is blue and one is not...can anyone help me out? oh and there is a $20 difference between the two
    http://www.carpartsdiscount.com/aut...s/aisin_brake_master_cylinder.html?3593=84122
    blue one
    http://www.carpartsdiscount.com/aut...s/aisin_brake_master_cylinder.html?3593=84121
  11. IronNam
    hope it works out!
  12. joeynational
    PHX,AZ
    91 2WD
