Newbie from Socal
Discussion in 'Introduce Yourself' started by badtzracr85, Jan 26, 2010.
  1. badtzracr85
    badtzracr85 Newbie
    North Hollywood
    84 EFI 22R P/U
    hey guys i just joined i live in North Hollywood CA Aka Sanfer valley. i own a 84 toy EFi . :runaway:
  2. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Welcome to TM! Have any pics of your truck and what are the plans for it?
  3. Toyo Trucker
    Toyo Trucker Addict
    You should sell your truck and buy mine.:clapping:
  4. johnpaul
    johnpaul Member
    no la
    92 xcab 2.4
    Welcome
  5. yota4life
    Welcome. But pics are a most around these parts
  6. badtzracr85
    badtzracr85 Newbie
    North Hollywood
    84 EFI 22R P/U
    here are some pix its a work in progress i want to lower maybe 2in and Add Intake and Exhaust any Recomendations? gonna paint her forrest green
  7. Shadetree Mechanic
    Shadetree Mechanic Addict
    Emerald Triangle, CA
    (I'm assuming you meant lower it 2 inches from stock height) Crank the torsions and do a ball joint flip for the front. Pull the middle leafs in the rear. That's just a start and your truck won't be level afterwards, you'll probably want blocks to get the rear as low as you want the front, unless you like a raked stance. I'd do 3/3 drop or more. A 3/3 drop is pretty moderate IMO.:shrug: A search of the forums should give you everything you need to know about ball joint flips, cranking torsions, and pulling middle leafs. These are all free and undoable process should you be unhappy with the effect on your ride or if you want to upgrade later.
    Welcome to the forum!
  8. SD YOTA
    looks like you got a good base for a good project truck. welcome to the site. :waytogo:
    take a look around here........ you'll find some good info on what to do.
    me personally, i like the magnaflow mufflers on these trucks. they sound pretty good. definately get a 4-1 header if you can find one around craigslist for cheap...... intake you may wanna look at LCengineering. not really sure who makes them anymore for the 22re's anymore.
  9. burnzya
    welcome to TM!
