new to toyotas...need some help
Discussion in 'Introduce Yourself' started by 70_boosted, Jan 24, 2010.
  1. 70_boosted
    70_boosted Newbie
    whats up everyone...new to toyotas, have done as much research as i could trying to find my answers but figured it was time to get the help from an online forum.
    i picked up an old 42 ford with a toyota front and back half...cant find any info on what year frame/suspension he used. the run 6 lug pattern, and yea...
    ill post a couple pics in hopes that someone could really really help me....:confused:
      File size:
      82 KB
      70
      File size:
      49.6 KB
      82
  2. burnzya
    i would call that a 79-83 yota frame... but it should be a 5 lug. only yota 4x4's are 6 lug. maybe somebody swapped in 4x4 spindles.
    can you post some up close pics of the back of the wheel and spindle?
  3. burnzya
    and welcome to the forum!
  4. Darrin87
    Darrin87 Member
    Yulee, FL.
    87 xcab long bed 22r
  5. burnzya
  6. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Looks like a mazda frame. As mentioned, B series Mazda would be 6 lug. I just looked at my mazda and the front bumper mounts are the same as yours with one bolt on top and one from the front. My Mazda also has the same cross member with the holes. Im getting ready for work so Ill try taking some pics later so you can try to compare my mazda to your frame. Mazda B2000,B2200 86-93 could be what you have. Nissan D21 hardbody 86-97 also was 6 lug and the front bumper mounted the same way.
  7. 70_boosted
    70_boosted Newbie
    here is a couple more pics, but from what i see, it looks identical to your mazda setup...is that good or bad?
      File size:
      98.8 KB
      43
      File size:
      111.2 KB
      58
      File size:
      18.8 KB
      40
  8. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    mazda b2200
  9. 70_boosted
    70_boosted Newbie
    that looks alot like mine despite where dude hacked and modified the bag mounts with some poor cutting and welding:brickknock: how would i go about converting to a 5 lug? is there spacers out there? kits to do it? etc...im going to be running a z-d rear frame piece gm 10bolt with the 5 lug...only because im running a turbo'd v8, unless i can be pursuaded to run a smaller motor...turbo'd of course
  10. Shadetree Mechanic
    Shadetree Mechanic Addict
    Emerald Triangle, CA
    I just wanted to point out that GM didn't offer the same lug pattern on any of their vehicles as the Toyota pattern which is 5X114.3. GM did offer some with a 5X115 pattern which might be close enough to work without adverse effects, but the pattern is different. Why do you want to use a 10 bolt rear end, anyway?
  11. 70_boosted
    70_boosted Newbie
    well im getting a fully built rearend and rectangular tubing in return for my entire c-notched back half. but im going with a skyline drivetrain so im thinking i may need to go with another rearend in general
  12. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    You got some nasty plans for that thing by that sound of it. So a boosted rb on a mazda frame with a ford body. Bad ass
  13. Shadetree Mechanic
    Yeah, that thing is gonna be sweet!
    Right on. I figured it was some reason like this. I was just wondering since I haven't ever heard the 10 bolt described as a super desirable rear end, although I have heard it is comparable in strength to a dana 44. Welcome to the forum by the way!
  14. 70_boosted
    70_boosted Newbie
    yea plans are for a fun ride to play with but not to really worry about show like looks.
    a buddy gave me his 10 bolt that came out of his dads 69 chevelle, was fully rebuilt, all in exchange for my backhalf.
    so i figured how to set that axle bolt pattern up, with the mazda front...
