Charcoal canister???
Discussion in 'Engine/Drivetrain' started by 22r, Jan 1, 2010.
  1. 22r
    22r Veteran
    Maui
    does this serve a purpose other than emmisions? bcuz i wanna bypass and plug all that and remove it so i have a clean engine look. thanxs.
  2. SD YOTA
    no need for it other than emissions........ its dumpster bait.
  3. standardbyker88
    haha. nice term. and yes, it just takes fumes that leave the gas tank and trys to clean them for the air a little. sure is a big ugly thing though. theres quite a bit of mess that can be cleaned up.
  4. standardbyker88
    heres a few quick ones of how clean these bays can get fairly easily.
    the rust is only because i hammered my inners so much for clearance that all the paint cracked off. lol. i also shaved all the extra bolt holes/mounts on the valve cover. and took out my a/c stuff. i have a freshly rebuilt head and intake as well, and swapped to the smaller 81 style master/booster.
  5. 22r
    22r Veteran
    Maui
    u wanna sell ur ac stuff?
  6. IronNam
    I love my AC :D
    you carb guys make engine bay cleaning look so easy....
    I need to do my battery intake swap....
  7. Paz
    Paz Member
    Downey, CA
    89 Toy Pickup
    the way u painted that new cover is SICK!
  8. 22r
    22r Veteran
    Maui
    haha! it gets super hot over here especially after school. lol!!!
  9. 22r
    22r Veteran
    Maui
    your truck has an electric fuel pump?? is that stock or did you install tht yourself?ive been thinking about putting one in and canceling my mechanical one.
  10. NotAvailable
    NotAvailable Addict
    im looking to get an electrical fuel pump too clean up the bay that much more...i run ac on my 22r and my motor is pretty clean because i shaved alot of my smog stuff and alot of unnecessary ground wires that i hid n grounded else where...good luck bro...
  11. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Can it be removed on an EFI engine?
  12. FOKAI12
    FOKAI12 Enthusiast
    GREW UP IN GUAM NOW IN VA.
    1992 Reg Cab
    Here is a Pic of mine once I removed all that cluttered canisters. I love how open and clean it makes it look once you remove all that crap.
  13. millcitysboy606
    millcitysboy606 Enthusiast
    Lowell, MA
    87 Pickup
    man i want to do that... looks clean as hell.. what can i remove to get it that way???
  14. 93Yoter
    93Yoter Addict
    Central Point, OR
    93 std. cab deluxe
    yes, along with both vsv's, the bsv, ac idle up, ps idle up, egr valve, egr modulator, and related vacuum lines. On my 4runner 22re I have a vacuum line from the charcoal canister to the throttle body, the brake booster, and the intake manifold to the fpr. That's it.....
  15. standardbyker88
    yeah i spent alot of time on that valve cover. shaved off extra mounts and even that raised front area the sticker sits on. i will sell it when i do a new one in powder coat with a new color. and yes stock electric pump in tank. i could sell the brackets, pump, lines and engine room parts most the dash stuff youd have to figure since its part of my heater core and never took it all out. i removed enine room stuff to clean it up since it needed to be recharged
  16. 22r
    22r Veteran
    Maui
    yah pm me your details! yesss ac haahha, and yup not available, i goin try do something this weekend and post pics and stuff, lol and one day after school ill just rip all that **** out.
  17. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    uhhh....ok...so you still have the charcoal canister??? I'm gonna run ac, so should I keep the ac idle up? you got any pics?
  18. NotAvailable
    NotAvailable Addict
    im currrently redoing all my wires..heres a pic...itll look cleaner and its really easy just time consuming cuz i hate electrical work -__-
  19. standardbyker88
    ill do up a valve cover like that for you if you send me a core. for anybody. its not that tough. i like working with aluminum
  20. 22r
    22r Veteran
    Maui
    if i was u id keep all the idle up stuff, its there so your truck doesnt die when its under loads.
