bag'd/bodyd 86 yota
Discussion in '1984-1988 Build-Up/Project Threads' started by neverdone, May 27, 2009.
  1. neverdone
    neverdone Member
    spring hill,fl (352)
    86 bodied yota
    project from hell..lol, 86 yota w/22r that is on its last life, body is shot, 2 accidents in 3 days...bastards..lol, but its going to be a totally different truck when i'm done w/it hehe:D
  2. neverdone
    neverdone Member
    86 bodied yota
    started working on the tag box...all welded in and ready for bondo but a few days later i some careless chick rearended me at a red light..lol
  3. bootleg
    bootleg Enthusiast
    Oregon Coast
    1990 4-speed
    ouch: all that work, gone in a blink of an eye,.
  4. neverdone
    neverdone Member
    86 bodied yota
    yea its structurally messed up.,..lol...but its kinda motivating me to build my 6.0/lq4 for it..lol
  5. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Man there is nothing worse than hearing about a Yota getting hit. Man that sucks. But now you get to have some more fun with it!
  6. neverdone
    neverdone Member
    86 bodied yota
    pics of the 6.0 getting torn apart
  7. neverdone
    neverdone Member
    86 bodied yota
    bought it for $250...w/wiring harness but w/4l80e..which i'm in search of now..lol....it being out of an "hd 2500" gives one option for a trans...the trans it came with...reason being because the crank is .44 bigger than a stock ls1 crank, which makes the seal pad bigger and different rear main, the ls1 crank will work but the motor will have to be re-balanced, i have the stock crank and an ls1 crank that i bought for $50 tht needs to be grinded and polished....doing this on such a tight budget is kinda of leaning me towards the stock crank
    took the intake,wiring harness,water pump,a/c compressor,bracketry, exhaust mani's, coil packs...etc
  8. neverdone
    neverdone Member
    86 bodied yota
    tonneau cover i built this w/end..did it soo cheap...kinda got lucky w/it..lol, but it works and havent got a ticket in two weeks so its workin.woot woot
    metal w/vinyl strip- free(took down display at my store)
    vinyl- 2 72x54 sheets or black marine-$40
    hinges-$5
    staples-free (work)
    screws-$5
    aluminum strip to cover seam-$23 =(
  9. StupidSheet
    StupidSheet Addict
    Canada
    Looks good, I like it!
  10. TDS909
    TDS909 Veteran
    ONTARIO
    1992 st cab
    nice
    right on thats a cool project you got there,
  11. neverdone
    neverdone Member
    86 bodied yota
    thx guys, should be really tearing her down when i get something else for a daily..lol
  12. neverdone
    neverdone Member
    86 bodied yota
    update:
    gave the body dropped bed away for free...i think i'm going bedless..lol
    cut off previous owners horrible tub job and core support
    pulled and sold 22r and 5sod trans
  13. Sam78
    Sam78 Enthusiast
    Oceanside
    78 toyota longbed 5speed 20R
    This is sad,
  14. neverdone
    neverdone Member
    86 bodied yota
    o ya why is tht ?..lol
  15. 89dlx47
    89dlx47 Veteran
    st. louis
    89 standard 2wd
    why does this dude never have anything positive to say? and neverdone your truck looks pretty good
  16. neverdone
    neverdone Member
    86 bodied yota
    lol...thx dude, appreciate it....i ended up buying two 5.3 vortecs....same ls-series as my 6.0 but have lower miles n more tranny options...had to jump on it...so i can use the 6.0 in my 67, got both 5.3's for 300 off some dude hurting for mula
    ...i also cut down my 64 merc montery wagon dash to fit the yota cab but need finish tacking that back together...making it bolt in as well..pics up later this week
  17. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    Drop some ls1 heads on that 5.3 and you're set!
  18. neverdone
    neverdone Member
    86 bodied yota
    yea that would help hp wise...i got lucky with these two motors...they both have aluminum heads..lol, which will less weight on my bags
    ...its deff a good idea predracer...i have a spare ls1 intake,crank, and cam but its a build on a really tight budget so i'm going to take my chances and go with a stock 5.3...i wont catch traction either way..lol....
    pics of dash..so far:
  19. neverdone
    neverdone Member
    86 bodied yota
    dash update:
    needed to section(shorten) 5 3/4" out of the dash side to side once steering column was centered...i started by cutting the dash in 2 but i needed to decide where to make my cuts before anything was done...so after measuring again again and again i chose to delete the radio because it was the flatest section.....the radio being 8 inches wide, screwed with my measurements...so i kept the right side knob of the radio and trimmed the 1st piece(driver side half) 3 1/2" and the 2nd piece(pass side half) 2 1/4" to get my fitment...they're not tacked together yet but its fits better than i thought it would...obviously needs "clean up metal work" done around the egdes which will be a bitch and flowing it into the doors...but i think i will like it...ecspecially since it will be bolt in
  20. lownloud
    lownloud Toyotaholic
    Plains, Montana
    Keep up the updates, very kewl . . .
