Biggest rims and still lays frame
Discussion in 'Wheels/Tires' started by Zwalker, Mar 11, 2009.
  1. Collins94
    Collins94 Addict
    communist virginia
    94 single cab hilux
    would it affect the clutch if you moved the clutch master cylinder to the inside of the cab because that was all that was keeping me from laying out on 20s
    my master cylinder is recessed into the firewall btw too
  2. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    You could move it inside the cab and just make the new arm for the pedel and all. I've seen a few bd'd trucks like that. Probably should do that before you finish up your interior.
  3. YotaMaster
    YotaMaster Member
    Grove, Oklahoma
    Bagged 1988 toyota,79 datsun kingcab
    i posted this on another thread bad ass 93 toyota, 22s, 383 stroker 670 horespower body dropped, top chopped custom upper and lower control arms supra rearend full rollcage
  4. the_general626
    La Mirada, CA
    k so i know its not a 2nd gen n its not 22's, but 20s by 8.5s on a 90 p/u? is it possible or wut without having to cut the wheel wells/hubs (w/e theyre called) in the front and back with a 3" static drop?
  5. neverdone
    neverdone Member
    spring hill,fl (352)
    86 bodied yota
    my 86 yota.....bagged n 2 1/2 trad body drop on 19's
  6. bustedknuckles
    bustedknuckles Enthusiast
    Las Cruces, NM
    1985 Toyota, 2000 S10 Xtreme
    loasian's truck is pretty sick. I love the frame. I just keep staring at it, and drooling a bit also.
  7. 89dlx47
    89dlx47 Veteran
    st. louis
    89 standard 2wd
    its for sale now. i saw it at heatwave
  8. TRUCK ACTION
    LoAsain's is the best one out there!
    But big wheels are over done/rated,every one wants bigger & bigger,no thought as to rolling mass/stopping/bearing wear,etc.!
    Just my 2cent's!:cool:
  9. Rayvin
    Rayvin Member
    I wana know how close can you get it to the doors with out wheels coming thru the hood with wat size rim/tyres?... i want to run r17/40 or 45.
    I'm liking Bunzya's idea with sectioning the fenders to get more room :/
  10. bustedknuckles
    Las Cruces, NM
    That datsun is crazy
  11. burnzya
    this truck has a piece of 1/4" plate welded to the very top edge of the original rocker panel. he has 205/40/r17
