305 chevy to a toyota v-6 trans
Discussion in 'Engine/Drivetrain' started by LOW-YOTA, Oct 19, 2009.
  1. LOW-YOTA
    LOW-YOTA Newbie
    MANDEVILLE LA.
    1992 TOYOTA P-UP
    does anyone make a conversion kit to bolt a chevy 305 to a v-6 transmission. what is the toyota trans called
  2. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    i know there is a ton of aftermarket kits for a 350 but not sure about a 305.
    google "toyota truck 350" and be astounded at the results
  3. project_DragTruck_v2.0
    if it´l swap a 350, it will work for a 305 because the block is the same....the difference is in the bore and stroke. All GM blocks are the same from 283- 400 ci.
  4. thundering02
    thundering02 Addict
    Fenton 63026
    Slight differences based on the years but nothing to do with what hes looking for.
    some had fuel pump holes and the head bolts differed between the different displacements.
  5. project_DragTruck_v2.0
    Well, I meant as far as mount placement, and bell housing bolt locations. Trans dapt should make a plate for that I´d imagine.
