im guessing maybe its the wrong filetype. Is it a jpeg or a bmp? I think it has to be a jpg, but if you upload it to photobucket and direct link it then it doesnt matter.
the wheels will fit, not sure bout the tires, tho. my 18's are off a Charger/Magnum yeah, check the jpeg. good call, Dan! we both tried uploading from photobucket, can't get it to work.
Those rims are pretty nice. They might look good powder coated too. Or chromed but that would be pretty spendy...
I have no idea. I did it like how dave said, save in a folder and it says "This is not a valid image file." I think you could be right. Ill reupload tomorrow sometime on tinypic.
when you open the folder its in, just click once on the image file. on the left side it should have some info bout the image. it should tell you what format its in.
Irfanview is a handy utility for changing filetypes on images. Works with pretty much all types. Just drag your image into irfanview and save as and change the file type to .jpg. http://www.irfanview.com/main_download_engl.htm (It's free.)
ah screw it ill reload it tomorrow. Im gonna head out guys. Early to sleep so i can get up early. Shoots guys.
