question cus im pretty new at this stuff
Discussion in 'Engine/Drivetrain' started by the bodj, Jul 27, 2009.
  1. the bodj
    the bodj Member
    i am currently rebuilding my 22re, and since i already have it off, i would possible like to turbo it, and get some cams, but i have a question about the turbo. would i be able to just put on the turbo and all the parts needed, or would i have to get the 22rte block? i am new to turboing stuff, and i wont be doing the work by myself. i will be having my dad (mechanic for 15 years) help me. i tried searching, and didnt see anything. thanks in advance. oh and ill get pics up of the rebuild when done.:)
  2. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Can't help you with your motor questions, but you can start a build thread in the proper year section. That way you can show your progress on the truck and motor.
    btw, welcome to TM!
  3. the bodj
    the bodj Member
    its all good. im sure someone on here will help. ive been looking around on here for a while, but that was my first post. and i plan on doing a buildup thread soon. btw its a 1995 2wd. i cant decide if i want to lower it a bit, or lift it a bit. most of the people on here will brobably say lower though lol.
  4. IronNam
    only downfall to slapping a turbo on a 22RE is the factory ECU
  5. 98tacoma27
    98tacoma27 Newbie
    Central PA
    05 SR5 Tundy, 88 single cab SR5 22RE
    What's the issue with the ECU? Finding one?
  6. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    ya you'll need the 22ret ecu.
    the big difference for the 22ret is the oil feed/drain on the exhaust side of the motor. but its not necessary, you can tap for oil under pressure from the intake side and dump into the pan where ever you want.
    really good site for info on the 22ret http://22returbo.net/
  7. 98tacoma27
    98tacoma27 Newbie
    Central PA
  8. IronNam
    then the Vane Air Flow Meter comes into question
  9. 98tacoma27
    98tacoma27 Newbie
    Central PA
    I see one on ebay for the 3.0 but that's it. I never knew they turboed the 22r from the factory until I was researching my truck.
  10. the bodj
    the bodj Member
    thanks guys. ive decided not to turbo it, but instead i think im going to cam it, so i have a bit more power to run bigger tires. im going to lift it too.
