New Chic in town..
Discussion in 'Introduce Yourself' started by 1htminichic, Feb 6, 2008.
  1. 1htminichic
    1htminichic Newbie
    Good Ole Virginia
    87 standard p/u
    Just wanted to stop in and introduce myself... I'm a little new at this so here is goes. I'm the wife of a Custom Taco mini trucker and I have now joined the encrypted world of the mini's.. I have an 87 standard toyota p/u lowered 3/3rims and exhaust it's not much but I had to start some where.. Soon to come will be the interior and paint/body work... :D This is all so exciting
  2. OGtoy
    OGtoy Enthusiast
    Oahu, Hawaii
    93 std cab 22re
    post pics of your truckkk!!
  3. 1htminichic
    1htminichic Newbie
    Good Ole Virginia
    87 standard p/u
    I tried it's telling me they are too big in size... the latest is the one on my avatar:rolleyes:
  4. cEElint
    cEElint Enthusiast
    Bakerstink, CA
    '91 Yota STD
  5. 79muttyota
    79muttyota Enthusiast
    Rome, GA
    79 sr5
    use photbucket. it's free and easy. they downsize the pic if needed. and welcome to the party.:)
  6. 1htminichic
    1htminichic Newbie
    Good Ole Virginia
    87 standard p/u
    Thanks to all and I posted some pics in my gallery if that helps for now... I will be ordering the interior when I get my tax money already filed just waiting on the return.. Thanks for the warm welcome. It's definitely a unique feeling to be a part of this crowd...
  7. patriotpop
    patriotpop Addict
    Baltimore, MD
    94 2wd
    Welcome! :)
  8. rolledz71
    rolledz71 Member
    ohio
    87 regcabswb
    cool looking truck,i like it with those wheels!
  9. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    welcome
  10. lownloud
    lownloud Toyotaholic
    Plains, Montana
    Welcome . . .
    Welcome to Toyotamini's ! Great looking project truck ! Especially because itsa 87' like mine ! Good Luck with the projects on your ride ! Cya in the forums !
    L o w N l o u d
  11. Litneon
    Welcome, it'll be good to have another perspective on things.
  12. 1htminichic
    1htminichic Newbie
    Good Ole Virginia
    87 standard p/u
    Thanks everyone for all the Warm Welcome's.. I'm glad to be a part of this forum... I have decided against getting a new Dooney Handbag in order to get new seats and carpeting for the mini :rolleyes: I have some samples coming from stockinteriors.com for the carpeting and I'm going to hunt for some new seats when the tax funds arrive ;) . It currently has celica (older style) buckets and they are worn and torn to the max so I'm looking for some accord or civic maybe even celica seats.. Please feel free to provide me with any suggestions you may have and advice on installation? I plan to also insulate the interior somthing similar to the process of Dynomat which personally I think is BLAH! So I'm looking for other options. Once again suggestions welcomed! Now as far as the dash goes it's not cracking or anything but I would like to cover it to match so I also need suggestions ... Thanks a bunch:)
  13. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    i got a roll of carpet from pep boys that im going to line the back of my cab with... also doing it as a head liner and doors.. justa thought..
  14. lownloud
    Plains, Montana
    somes ideals . . .
    Well, when I did my interior soundproofing / insulation, I wasnt going to half-a*s it. I used the site http://www.yourautotrim.com/I found alot of really kewl samples for both my fabric on doors, headliner, and soundproofing/insulations. When I did the floor, I stripped everything out of it down to the bare metal, I scraped the crud & vacuumed it out, I then used a spray undercoater to cover everything. Then, I used the Thermozite Heat Shield Carpet Padding on the entire floor and the firewall ( some totally awesome stuff and hella easy to lay down. I installed a molded ( black ) carpet insert. Before I mounted my subwoofer box behind the seat I used 2 layers of dynamat original on the back of the cab, and 1 on the sides where the cab vents are. I then built my sub-box, installed it, sealed it with undercoater and dynamat extreme inside and out. After the box was installed I used the (black) 80" Wide Superflex Ozite Automotive Carpet and did everything from the floor up including the box really inexpensive and very good quality. So I did use dynamat, but I covered it so itll never be seen but, is in use. I ended up taking the jute back up and puting 1 layer of dynamat original on the floor then put then I put the carpet back down. Mind you this is hella overkill, But, my roadnoise is next to nothing, not even a new car is sealed up this tight and overall with carpeting cost me around 250 $. I went further and soundproofed the inside of the doors with spray noise blocker. So I dont hear anything but the music.
    L o w N l o u d
  15. TRUCK ACTION
    Yeah, I remember the day I brought my baby home, a replacement work truck for the 86 I totaled. Never thought it would someday look like it does now!!
    Welcome.:cool:
  16. 1htminichic
    1htminichic Newbie
    Good Ole Virginia
    87 standard p/u
    Yeah I can't wait all hubby has to do is bleed the breaks and change the oil one more time and it will be home... Trust I will be on the first ride around the block.. I have to say this is almost as exciting as getting a new car for me :) One more thing is that I have a stock radio for now :-( :rolleyes:
  17. Darrin87
    Darrin87 Member
    Yulee, FL.
    87 xcab long bed 22r
    For the sound deading, You can get 100sq ft of Fatmat for 129.99 its some really good stuff and cost a hell of a lot less then dynamat.
  18. east1la
    east1la Enthusiast
    nc
    1993 toyota pickup dually
    welcome to tm.
