looking for air ride compry essor
Discussion in 'Wanted' started by krazedprof, Jun 28, 2009.
  1. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    i am in need of a compressor as i have a very small one and until i get my edc mounted i need a compressor to air my truck up and i am installing 8 valves so i just need something to fill my tank thanks
  2. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Look on www.yotascene.com. There is a guy selling a new Viair 450C for a good price.
  3. krazedprof
    krazedprof Addict
    iowa
    well i found a used ob1 air zenith for 125 plus shipping i think thats a good deal cause i priced the rebuild kit if it needed it so i think its a good deal can anyone tell me if that is a good price. also said it works great
  4. paintinSTR8
    paintinSTR8 Member
    Galt Ca.
    93 Yota 2wd reg cab
    damn man i spent $40 for my ac compressor at a pick in pull, with the bracket. and modifided the bracket a lil and had it all hooked up in about 2-3 hours. best thing i ever did compressor wise. 1 one lasted over a year, and the one thats on now is going on 2 years, drive it daily and i am one toggle switch happy mofo:funnyup:
  5. krazedprof
    krazedprof Addict
    iowa
    yeah im in iowa and the wrecking yards here don't have toyotas and if they ever get them in all the parts are sold immediately:(
  6. paintinSTR8
    paintinSTR8 Member
    Galt Ca.
    93 Yota 2wd reg cab
    it does not have to be a yota. as long as its the rite kind of ac compressor it will work.
  7. krazedprof
    krazedprof Addict
    iowa
    i have a york 210 compressor right now but no brackets and im not any good at fabbing anything
  8. paintinSTR8
    paintinSTR8 Member
    Galt Ca.
    93 Yota 2wd reg cab
    if you can make a good template of exactly what you would need take that to a local welding shop to have it fabed. would probably be less than that used air zenith
  9. krazedprof
    krazedprof Addict
    iowa
    yeah probably could i might just buy the zenith for a back up though just in case you know
  10. paintinSTR8
    paintinSTR8 Member
    Galt Ca.
    93 Yota 2wd reg cab
    wouldnt hurt. guess im just not a fan of electric compressors any more, been through like 5 of them, but i was running them like crazy. ive never heard anything bad about the air zenith. go for it
  11. krazedprof
    krazedprof Addict
    iowa
    thanks for the input i seen i can get a rebuild kit for 59 dollars so i figure its not that bad of a deal
  12. paintinSTR8
    paintinSTR8 Member
    Galt Ca.
    93 Yota 2wd reg cab
    yeah thats not bad at all. lets see some more pics
  13. krazedprof
    krazedprof Addict
    iowa
  14. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Im not sure what or if you need anything else, but look on www.mautofied.com too.
  15. krazedprof
    krazedprof Addict
    iowa
    well i bought the air zenith for now
  16. paintinSTR8
    paintinSTR8 Member
    Galt Ca.
    93 Yota 2wd reg cab
    nice let us know how it works when you get it hooked
  17. ShortyzKustomz
    ShortyzKustomz Enthusiast
    Central Va.
    94 Single Cab
    go to pirate4x4.com for all the mounting info for your York (I have some diagrams too), My brother might have a viar 450 for sale cheap...I sold my 450 a few months ago
  18. krazedprof
    krazedprof Addict
    iowa
    yeah i looked at some of those but if you have a diagram too let me know also let me know about the compressor thanks
  19. standardbyker88
    i dont know if it helps any. but ive always liked when guys use threaded rod, take a length of round bar, and tap it inside for the threaded rod. then make a nice end part, which is basically just the round bar ground flat into a little tab, then drilled. sorta like making tiny link bars, and if its done right, you can adjust one side to tighten the belt on it up. i dont have any pictures though.
