Project Gudlux
Discussion in 'Pre-1975 Build-Up/Project Threads' started by swapmeet, May 8, 2009.
  1. swapmeet
    swapmeet Enthusiast
    I'm a little scared of the whole 'moving the clutch master cyl' thing... Seems very involved...
    I'm not sure if my upper control arms can handle me being much lower, they are pretty much standing straight up at 12 o'clock right now. Once I get the passenger side done, i'll have a better idea where i'm at and what else I might need to do.
    LOL I perfer "tucking like a motor home" :D
  2. burnzya
    i think a set of custom upper controls arms would fix your problems. when you modified the uppers to get the right ball joint angle it essentially shortened the arm. if you get a custom set with the proper ball joint angle built in (and using the stock length from the ball joint to the crossshaft) it would push the top of the tire out. i would imagine it would let you clear the clutch m/c and help with the camber.
  3. swapmeet
    swapmeet Enthusiast
    Help?
    I didn't know i had a camber problem... :shrug:
    :ROFL:
    I love... LOVE my camber. Plus it levels out at ride height... believe it or not, I have a little over a 1/4" of shims ADDING camber on the front that I have not taken out. Once I go in for a full alignment, i'll know better where I stand.
    I appreicate the suggestion, and you are probably right...
    I bet I could make a oval shaped cut around the clutch cylinder with the upper part of the oval above it, pull the panel out, flip it over, and re mount the cylinder. Effectively raising it.
    Like I said, It may not lay that hard once i have the passenger side done...
    Did I mention I like camber? :headbang:
  4. burnzya
    :D, i like camber as well! i was just suggesting it so you didn't have to mod the clutch m/c. i'm gunna be in the same boat soon with my 73. i'm shootin for 20" or 22" rims with a body drop!
  5. burnzya
    did that diagram help you?
  6. swapmeet
    swapmeet Enthusiast
    Unfortunately no, I only have one fitting on the distributor... so dist. advance.. but no dist retard... :shrug:
    I remounted the magical box, and pluged it, but the vac advance on the dizzy is hooked straight to the intake...
  7. swapmeet
    swapmeet Enthusiast
    Not done yet, but it goes up & down like it should...
  8. StupidSheet
    StupidSheet Addict
    Canada
    That thing is so SEXY! Let me know when you're finished so I can buy it. LOL.
  9. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Damn that thing looks good! Is that a mudflap thats being bent by the ground behind the rear tire in the 3rd pic? :lol:
  10. swapmeet
    swapmeet Enthusiast
    Yes sir...
    OG Toyota mudflap with the Japanese Logo...
    They're stayin till I drag them off.
  11. swapmeet
    swapmeet Enthusiast
    ^^^ LOL
    And here are some more... for your veiwing pleazasure! Its about 93% done... just a handfull of details to make it 'complete'.
  12. burnzya
    nice touch with the batteries!
  13. the_general626
    La Mirada, CA
    yea ur trucks sexy! lol
  14. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    those mudflaps are awesome.
    trucks not to bad either :D
  15. nvrenufedge
    Caldwell, ID
    bagged '93 std cab
    Yea, I like the battery box!
  16. 89dlx47
    89dlx47 Veteran
    st. louis
    89 standard 2wd
    x2 i love them
  17. lownloud
    lownloud Toyotaholic
    Plains, Montana
    Way kewl, everytime I see this mini it gets even more bada**! Love the upgrades, dig the flaps, and love the theme. Keep up the great work and thanks for sharing with us . . .
  18. Umtali
    Umtali Member
    Portugal
    1973 Hilux
    Can you do me a favour and send me large photos of the "HILUX" badge on the tailgate as well as measurements ... I want to reproduce that for my restore project! :waytogo:
    PS - I´ll take the mudflaps off you before they get ripped off ... ;) and do you still have the original floor mats?
  19. swapmeet
    swapmeet Enthusiast
    The mud flaps stay sir...
    And no, I have no floor mats. I'll try to remember to get you that picture/ measurements.
    Do you know where I can get a new drag link with a new ball joint in it??? My steering is kinda sloppy.
  20. randyman
    randyman Enthusiast
    georgia
    1976 hi lux 2x4
    can u say groovy ??
