Rearend
Discussion in 'Wanted' started by IBeSeeN, Jun 15, 2009.
  1. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    Looking for a Good 8" 3.07 ratio rear end for a 4 cylinder
  2. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    mkIII+ supra.
    ive never heard of a truck with gearing that high
  3. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    89 with the 4 speed came with the 8" rear end and 3.07 gears stock :D someone put 3.43's in
  4. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    ahhh
    here i thought most 8in truck rears were 4.10 or better.
    i really wish there was a list of ALL yota rear ends, and what they came in. i can only find magic decoder list's. not something that says, "X.xx came in XX-XX years"
  5. IBeSeeN
    IBeSeeN Addict
    Harrisburg, Oregon
    89 Toyota
    yeah i know then it would make life easy for running threw the pick-a-part
  6. walkerman5000
    walkerman5000 Member
    Oklahoma
    89 2wd with a 22r
    How can you tell by looking at the rearend?
  7. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    The 8" with the 3.07 ratio has a slightly offset pinion, this is due to the size of the pinion gear. Look at the front of the carrier, or just find a 4speed 2wd in the yard.:)
  8. walkerman5000
    Oklahoma
    89 2wd with a 22r
    I have an 89 22r 2wd 4 speed and a bagged 94 22re 5 speed. I was thinking of unbagging the 94 and swapping the whole rear suspension. Would this throw my gearing way off on either truck? Not trying to jack your thread.
  9. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    The only thing I have is the 8" 3.07 (G662)3rd member. I do not have a whole axle. Do you need the whole axle?
  10. burnzya
    maybe swap the frames?
  11. SD YOTA
    you can take a look at the center of the rear drum where the hub sticks out....... 8" rear ends have 4 casting lines on the center of the hub. 7.5"s have 2 casting marks.
    if you swap your axles around...... your 5 speed equipped truck will have super high gearing...... like 80mph @ 3000rpms kinda gearing. your 4 speed will have the opposite effect and have low gearing....
