86 pickup carb issues
Discussion in 'Engine/Drivetrain' started by 86_Hilux_MN, Jun 17, 2009.
  1. 86_Hilux_MN
    86_Hilux_MN Newbie
    1986 Hilux 4 x 4
    ok new to the forum.
    have a 86 pickup that the floats in the carb are messed up and when you deccelerate it stalls out. runs and drives fines till you deccelerate.
    any idea's on a good fix???
    and yes i tried to search.
  2. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    do the floats still float?
    if they do, you can bend them a lil bit to increase the fuel in the bowl.
    your looking to get the fuel level to be about center of the sight glass with the truck level.
    this could also be a clogged fuel filter.
  3. 86_Hilux_MN
    86_Hilux_MN Newbie
    1986 Hilux 4 x 4
    Forgive me i am not a Carb specialist, but if the floats are not returning when the fuel is returned causing it to stall out when coming to a stop, would a simple rebuild kit from napa do the trick?:shrug:
  4. 86_Hilux_MN
    86_Hilux_MN Newbie
    1986 Hilux 4 x 4
    cause it starts idles fines even will drive until you start to come to stop then the stalling issue comes in.
  5. burnzya
    welcome! i wouldn't worry about anybody bitchin at ya for askin a question. pretty relaxed atmosphere here:waytogo: unlike some forums.
    i had a similar situation on my mustang with an edelbrock carb. it was flooding the motor when coming to a stop. i rebuilt the carb and it ran good for about a week, then started doing it again. pulled it back apart and found that the float had a pin hole and filled with gas. i replaced the floats and it's worked perfect ever since. the weird thing is the first time i built it the float was empty.
    i would recommend a rebuild, since most kits have a gauge for setting the floats. also make sure the float doesn't have a hole.
  6. 86_Hilux_MN
    86_Hilux_MN Newbie
    1986 Hilux 4 x 4
    Thanks for all the info. i will post up some pics soon.
  7. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Check your brake booster...
  8. burnzya
    ^ i think a vacuum leak would make the engine speed up.
  9. not forgotten
    not forgotten Addict
    Washington
    82 SR5 L/B
    Had a similiar problem with my stock one, decided the best thing to do was to just get it replaced with a weber replacement kit, runs like a champ now. Just looked at the box it reads replacemnt for Toyota 20-22R #K746, ran me $279 Dan, my fab guy installed it for $50, did an excellent job, also the truck has a new fuel pump and exhaust manifold, with everything else done to it its basically a brand new truck, aside from the body work and paint, Dan told me that while back and thought that was so cool for a truck thats over 27 years old.
    Hope you get the carb issue worked out,
    I know excatly how you feel.
  10. not forgotten
    Washington
    82 SR5 L/B
  11. curtisjackson
    curtisjackson Newbie
    It's really hard to deal with a non working carburetor, you dismantle the whole thing and clean it many times yet it's not performing well sometimes the only solution is to find carburetor rebuild kit that would replace some of the defective parts
  12. jrealmuto1
    jrealmuto1 Member
    MS
    1986 Yota 2wd
    id buy a weber 32/26....its better than the stock carb and you should have any problems in a loooooooooong time....but thats just me, $300 for new carb or rebuild the ol junky one..... :shrug:
