FS: 22RTE turbo parts
Discussion in 'Parts and Accessories' started by JamesD, Oct 26, 2008.
  1. celica83_gts
    celica83_gts Member
    Edmonton, Canada
    '90 Xtra cab 2wd
    Cool, How did you deal with the timing chain and piston issues? AFAIK the LASRE block and pistons would work with the early head, but without a dome on the piston the C/R would be low. Did you use OEM or custom pistons?
    Yeah, this thread was commandeered, sorry James. Mods, any comment?
  2. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    I could care less as long as one of you fukkers buy my stuff you can talk about whatever you want!!:D Seriously, if someone wants to take all the parts off my hands, I can make them a good deal.
    James
  3. HNG-10W
    HNG-10W Newbie
    Syd, AUS
    91 xcab
    gday mate..
    whats my chances of u sending that manifold to australia? how much do u think shipping would be and would i be able to put a garret t3 on with an adaptor?
    cheers
  4. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    As long as I receive US currency I would ship it. Also I do not have Paypal so you would have to figure a way to get me the money. NO checks what so ever. I only accept a United States Postal Money order or cash. If you have any friends in the states, I suggest you get them to pay for it and then I will ship it to you.
  5. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    Exhaust manifold and TB elbow is SOLD
  6. Nor Cal Moto & Speed
    Nor Cal Moto & Speed Newbie
    How about an ecu and wiring harness?? Anybody got one of them for sale???:confused:
  7. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    Look around. Check Yotatech.
    James
  8. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    ok I read through some of the mix matching parts rubble.
    with a 22r block, 86 and up. It WILL work with the early 80s head.. thats what I have on now..didnt need any timing adjustments.. just put on and go.
    as far as the pistons, dont mix match pistons with different blocks... if you got the right pistons your good...
  9. Sal-G.77
    Sal-G.77 Enthusiast
    Palmdale CA
    90 4RUN/22RE/2WD
    Hello.. I dont think anyone want a cracked manifold? And yes it will crack in the same place.
  10. JamesD
    JamesD Veteran
    NY
    93 Reg cab
    What are you talking about? It sold. If you weld it correctly it should not crack.
    Airbox is SOLD
    TB to pipe is SOLD
    James
