Its all about the rubber.
Discussion in 'Wheels/Tires' started by Megaglow_Z, May 20, 2009.
  1. Megaglow_Z
    Megaglow_Z Addict
    Benton la
    81 long-bed goodness
    OK.....lol
    I FINALY have my rim and spacer issue solved.
    Rims are 16 inch with a 1 1/4 inch spacer.
    Outer rim lip is exactly where the stock rim is with this and the inner lip is about 1/2 inch further back. slightly wider rim.
    On my truck (81) with the 3 inch drop i have, what tire size would be good to run?
    I am planning to drop it more and bag it.
    Is a P215/65 R16 to wide/tall?
    Truck has 205/70 r14 now
    What are you guys with 16 inch rims running?
  2. Megaglow_Z
    Megaglow_Z Addict
    Benton la
    cricket....cricket....cricket.
  3. IronNam
    we're running twenty fo inch donks
    :cricket reply:
  4. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Im running the smallest 16-inch tire there is...its a 205/40-16, but you can always go with a fatter/wider tire & run the 215/40-16 or a tire that is a little taller & thats the 205/50-16.
  5. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
  6. Megaglow_Z
    Megaglow_Z Addict
    Benton la
    Ill deal with you later..........:evil:
    Actualy, it did! thanks man.
  7. IronNam
    there's this (clean bodied...) S10 running around town (from the ghetto hood) with huge donks
  8. standardbyker88
    if you didnt solve this yet, i would suggest 205/50/16s all around, or a 225/50/16 for the rears. one is a stock focus size, one is a stock probe size. lots of other stuff its stock for too, but that means there are a lot of companies making them and they arent super spendy. also, they arent drastically shorter than stock. i ran the latter size all around on my 78 and its alot lower. without much drop i wouldnt run smaller than a 24" tall tire. looks weird.
  9. Toyo Trucker
    Toyo Trucker Addict
    Don't forget to check the load index.:rolleyes2:
  10. standardbyker88
    good point. focus and a probe weigh about the same, if not more. but i dont haul stuff. if i sit on the tailgate, i max out the rear suspension onto the frame. and im not a big guy either. haha.
