fuel filter
Discussion in 'Engine/Drivetrain' started by krazedprof, May 17, 2009.
  1. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    okay so i was putting my motor back together and i have no clue where the fuel filter goes and where the lines hook up any help would be very appreciative 91 22re if that helps also how does the bottom radiator hose hook up thanks
  2. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    The fuel filter that on the motor is a bitch lol...if your looking down at the engine from the front of the truck (Im assuming its in) it will be located on the left side under the EFI intake manifold. Its easier taking it off from the bottom on the engine cause its close to the oilpan.
  3. krazedprof
    krazedprof Addict
    iowa
    well no its not on the truck the whole motor was apart when i bought the truck and now im putting everything back together and i don't know where that mounts or where it hooks up to
  4. phil03
    phil03 Enthusiast
    ottawa,canada
    93 pick-up
    if you take the starter off it should make it alot easier and what do you mean by the lower rad hose, show some pictures should make it easier for us to understand what you mean!, good luck with the fuel filter and DON'T forget the 2 washers at the banjo bolts(one on each side of the line)
    Phil
  5. krazedprof
    krazedprof Addict
    iowa
    yeah i will get pics 2morrow as its dark now also where do the lines go from the filter thanks
  6. burnzya
    one comes from the tank, and the other goes to the fuel rail.
  7. krazedprof
    krazedprof Addict
    iowa
    thanks burnz i thought that was how it went but wasn't sure
  8. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
  9. burnzya
    when i got my 4x4 my friend said "its got a new fuel filter, but its not where it should be". i told him i was gunna put it where it belonged. after putting it where it belonged i realize why he didn't do it!
  10. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
  11. PapaBear1013
    PapaBear1013 Addict
    Lancaster, Cali
    1994 Std Cab
    dude fuel filters are a major P.I.T.A. I replaced my not to long ago, actually took the passenger side tire off and was able to get to it
  12. the_general626
    La Mirada, CA
    thats how i got mine out and it was still a bitch to get to!
  13. IronNam
    relocating it to the fender wall is the best success
  14. krazedprof
    krazedprof Addict
    iowa
    does the washers have to be copper on the banjo bolts cause i can only find 1 thanks
  15. burnzya
    yeah, i believe they are called a crush washer. one time use.
  16. krazedprof
    krazedprof Addict
    iowa
    where can i buy them at
  17. burnzya
    i would imagine napa would have them, assuming there is a napa near you. maybe the cheaper parts stores would have them but not too sure.
  18. krazedprof
    krazedprof Addict
    iowa
    i went to all 3 parts stores in my town and they said they never seen them for fuel lines lol also i need some for the the ones that go from the intake manifold to the fuel rail since they are a one time use only item cause i have only the old ones which were napa,carquest and oreilly's
  19. burnzya
    they should come with a new filter. i checked napa's site they range from $9-$30 depending on brand. the dealer would probably have them as well, and couldn't be too exspensive. i honestly re-used the ones on my 4x4, but they do leak a bit.
  20. krazedprof
    krazedprof Addict
    iowa
    ill try old ones first cause i am really close to getting this thing together so i can hear it run the guy i bought it from said it just needed to be put back together and it runs excellent also the truck only has 55,000 miles so im hoping it runs good if not im going to run a v8 in it.
