Dual Alts.
Discussion in 'Engine/Drivetrain' started by oahu grown, May 16, 2009.
  1. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Anyone in here running dual alternators? Plan to build up my sound system and wanted to add a second alt. I already picked it up, but its for a 3.0 instead so was thinking of running both of them If anyone has done this before can you post pics of what you did? Anyone have any advice? Thanks in advance.
  2. StupidSheet
    StupidSheet Addict
    Canada
  3. oahu grown
    Hawaii
    92 Extra Cab
    Thanks for the link man, ill look into the bracket more when i have more time:
    http://cgi.ebay.com/ebaymotors/Toyo...ViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3
    a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2e
    c0Q2em14QQhashZitem29fe26b442QQitemZ180357608514QQptZMotorsQ5fCarQ5fTruckQ5fPar
    tsQ5fAccessories
    What im worried about with that bracket is im not sure if my alt is a GM one. Looking at my alt the bottom part looks larger, but im not sure. Ill try and post some pics tomorrow.
    Anyone else got any info, tips or suggestions?
  4. Shadetree Mechanic
    Shadetree Mechanic Addict
    Emerald Triangle, CA
    This is actually the first time I have heard of running dual alts. On my 4x4 I am running a chevy one wire alternator. It is almost a bolt on fit although I did have to fab up a little part that offsets the lower alternator bolt/mount away from the engine to clear the larger housing on the chevy alternator. There is a range of options in output available depending on the alternator you choose to go with. I chose a lower output model as it was still quite a bit more charge than the stock unit and I didn't want it to rob too much horsepower. It made my headlights brighter and I no longer have charging issues when it is idling (50,000 volt ign). I guess I can see an advantage in that with dual alts you would have a back up if one failed, but personally I wouldn't want to give up the horsepower over it. I would try to run the smallest high amp alternator that would produce enough power for my needs. It is quite possible there is more to the dual alt thing though that I am unaware of.
  5. oahu grown
    Hawaii
    92 Extra Cab
    Thanks for the input. The whole reason i want to do this is so that i have a alt dedicated to my stereo system. I already have the alt. I checked and its a Iraggi 220a in a GM housing, so that EBay bracket kit will be perfect. I just have to find somewhere to put it and then splice the wiring. Heres some pics/ a preview on what i plan on doing. Enjoy. I plan to post more pics as the progress comes along, or at least make a new thread, so stay tuned.
    Iraggi 220a Alt in a GM casing
    I will be running 2 of these bad boys
    And for those that know what these are
  6. trap
    trap Addict
    orange county ca
    92 pickup
    cool stuff, where/how are you mounting those speakers?
  7. oahu grown
    Hawaii
    92 Extra Cab
    Hey someone in here knows their stuff. Not sure yet. In order to run these i need 1 3/4 spacers, so might be looking into other brands as well. Keep posted though, starting a build log real soon
