Bags on a daily driver?!?!
Discussion in 'Suspension/Chassis' started by joeynational, May 5, 2009.
  1. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    What do you guys think of this? How many of you have a DD that is on bags..just looking for some pros and cons..I am not thinking of anything radical,just something to lay it down when i park and with some decent speed, I was in a bagged s10 once and the ride actually seemed softer almost cadillac like haha ride quality is also an issue being its a DD..what are your thoughts?
  2. the_general626
    La Mirada, CA
    my boys car is bagged and thats his daily
    if u have a good set up, i dnt see y not, just dnt try to be speed racer lol
  3. dirty
    dirty Member
    garner NC
    when i get around to bagging mine it will be a daily.
    just overbuild it and take all the necessary precautions ti keep things from rubbing
  4. tehsk
    tehsk Enthusiast
    Northridge, CA
    88 2.4L Carb
    I also dream of a having a bagged daily. I don't think i'm too far off, I have the cash just looking for the perfect yota to come along.
  5. burnzya
    as long as you set it up right, and run the lines properly, you shouldn't have an issue having a bagged daily. until your in a rush and have to wait for it to air up:)
  6. joeynational
    PHX,AZ
    91 2WD
    would nitrogen be a better choice for DD than air
  7. burnzya
    i generally think of nitrogen for the guys that like to hop. but i've seen some guys run a small nitrogen bottle for situations when their in a rush, of if there is a problem with the compressors.
  8. the_general626
    La Mirada, CA
    wut does nitro do exactly?
  9. burnzya
    its just a compressed gas that can be used to air up the bags. but if you want a truck to hop (a lot) nitrogen works well, since the bottle is usually charged over 2,000psi. then u can regulate it down to 300 or so and have the truck fly like a bird. it takes it toll on the bags though.
  10. joeynational
    PHX,AZ
    91 2WD
    plus there is no moisture in it..
  11. the_general626
    La Mirada, CA
    so nitro is good and bad?
  12. burnzya
    it just depends on what you want. its better than straight air since its pure.
  13. joeynational
    PHX,AZ
    91 2WD
    if your not using max pressure from the nitro i think it would be ok on the bags.and also being there is no moisture your system might have a longer life..but it could be pain to constantly take out the tank and have it filled not to mention expensive...last i checked it was about $20-$30 to have filled
  14. burnzya
    ^^^^^ very true.
  15. the_general626
    La Mirada, CA
    damn that does add up
  16. 88Sandshark
    88Sandshark Toyotaholic
    Lake Elsinore, CA
    Nitrogen also helps prevent some leakages because the molecules are bigger, Costco uses it on their tires they install, my BFG's are Nitroed. sorry to thread jack.
  17. TRUCK ACTION
    I drive my truck @ lest 3 times a week,no problems.
    Plan & set up all to prevent any problems: valve manifolds close to bags, good fittings( not water fittings), run check valves,so no loss of air from bags,etc.
    Also correct electrical set up,so no fires!:cool:
  18. joeynational
    PHX,AZ
    91 2WD
    what compressor can handle the load of daily use?
  19. Collins94
    Collins94 Addict
    communist virginia
    94 single cab hilux
    one of the guys i hang with at shows had a silverado runnin off nitro on 2 tanks and he said he could get about 20 lifts out of it
  20. TRUCK ACTION
    I run duel 380's, in the process now of adding a 2nd tank, same as 1st,stainless 5 gal.
    I don't play, just wanted moire air supply,& a added look @the bed!
    Don't like steel tanks as a rust problem/ condiments is present in time.The stainless tanks don't come with a drain( don't know way not) so added to both tanks,as even with water traps ,water will get there!:cool:
