The Black Goop
Discussion in 'Maintenance/Repair' started by 88Sandshark, Mar 10, 2009.
  1. 88Sandshark
    88Sandshark Toyotaholic
    Lake Elsinore, CA
    Does anyone know what that nasty black crap is in the 22RE throttle body? Is it backdrafted oil from that hose where a breather would plug in?:shrug:
  2. Litneon
    It is in fact blow by from the crankcase ventilator. As part of the emissions, the engine burns this so that it doesn't land on the ground or go airborne.
    There are ways to eliminate this "green" option though....
  3. 88Sandshark
    Lake Elsinore, CA
    Would a breather clear that up? if so, what should I cover the hole on the intake manifold with?
  4. JOE_1985
    JOE_1985 Veteran
    87 custom
    catch can
  5. 88Sandshark
    Lake Elsinore, CA
    Eventually, I'll track down a breather and bypass cap to prevent that crap. I'm losing enough oil as it is...:mad:
  6. HaNd_SoLo
    HaNd_SoLo Enthusiast
    Sonora, CA
    1987 xtra cab long bed
    What I plan on doing on mine is run a compressor oil separator and a fuel filter inline. That way the PCV is still connected and functioning but all that crap isn't getting blown down the intake.
  7. 88Sandshark
    Lake Elsinore, CA
    Good idea. Post a pic whenever you do it, some of us may just try that.
  8. HaNd_SoLo
    Sonora, CA
    I liked the idea, but it wasn't mine. I saw in on an S10 forum. I can't find my bookmark but I did a google search for "catch can" when I found it.
  9. JOE_1985
    JOE_1985 Veteran
    87 custom
    i had one of those on my celica, worked good
