20r shorty header on 1995 22re...
Discussion in 'Engine/Drivetrain' started by Spenny, Jan 22, 2025.
Tags:
  1. Spenny
    Spenny Newbie
    Western Oregon
    95 toyota 2wd single
    Got a 20r shorty header, for my 1995 22re. The header dosnt seam to have a holes for the air injection system that i dont want anyways. Im getting exhaust gaskets for the 22re, but do i need a air injection block off plate to delete the air injection system with this type of header? Thank you!
  2. fred heath
    Not sure the 20R header will work on the 22RE. I believe the ports are different designs. I know the intakes are different.
  3. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    If the flange on the header does not have holes for the air injection manifold, then you do not need to get block off plates.
    20r and 22r EXHAUST port spacing should be the same. Toyota changed the air injection ports but the flange should cover both designs.
    BUT..
    There are two bolt patterns for exhaust manifolds. 20r and early 22r use seven bolts while later 22r use eight bolts. Newer headers made for the 22r usually have NINE holes (three holes between 2nd and 3rd exhaust ports) to be backward compatible for all 20r/early 22r/late 22r. Older headers made for 20r/early 22r will not work on later 22r. Unfortunately, I do not know when Toyota changed the manifolds but 95 is definitely the 8 bolt pattern.
    If you go to lce performance's website, you can see the differences in the header flanges in their pics. You can also see that they sell a shorty header that fits the 20r/22r/22re.
  4. Spenny
    Spenny Newbie
    Western Oregon
    Ok great info! The header i have has holes in every outside corner of the flange, and 3 in between the portholes in the lower flange. Its deffinetly missing 2 that the lce has that are centered ontop between the exhaust ports
  5. sirdeuce
    sirdeuce Veteran
    '86 4Runner and '89 2WD
    Be sure to retorque the nuts after a few heat cycles.
  6. sirdeuce
    sirdeuce Veteran
    Curious, 2 or 4 wheel drive? 2 wheel drive would benefit from long tubes and the shorty would be better for a 4X4.
  7. Spenny
    Spenny Newbie
    Western Oregon
    Its a 2wd early 1995, im sure its not "ideal" but its better then the current cracked manifold and broken y-pipe haha
  8. sirdeuce
    sirdeuce Veteran
    The late stock pieces are designed as a "tri-y" and that really works well with the 22R/E engine. Stock bits are restrictive, but they do work well with the stock engine. If you want to really bring that set-up to life a cam with @215 +/- duration at .050" lift with as much lift as you can get. I've run the Schneider 250/260F with shortys with good results, and WEB Camshafts 94a was a grunter as well. Not much to do with the 22RE if you keep the stock ECU and engine, just cam and exhaust.
