1977 tail light repop replacement wiring
Discussion in '1976-1983 Pickup Discussion' started by musicearlyadopter, Jun 3, 2024.
  1. musicearlyadopter
    musicearlyadopter Member
    I bought some new repop tailights (Thailand) for my 1977 pickup but the wiring harness plug (rectangle 5 conductor) is different than the OEM version (square/rectangular - 4 conductor plus a separate wire with spade plug for the tail light). Has anyone made this conversion and can tell me what wires go where?
  2. 83pickup
    83pickup Enthusiast
    Phoenix, AZ
    1983 22R Long Bed 5-Speed
    Do you have any pictures of the new wiring pigtail and the original ones on your truck?
  3. fred heath
    Your factory harness will have a total of 5 wires going to the rear tail lights. Your harness should have the same color code as my 1978/79. My harness color code:
    Grn- parking
    Grn/yel- R turn
    Grn/blk- L turn
    Red/purple- backup
    Grn/wht- brake
    Hope this helps.
    Erwin Merida and 83pickup like this.
  4. musicearlyadopter
    Thank you- I did figure it out with some trial and error and every light works now except the overhead map light- that is likely just a grounding issue, as it is a new repo light/mirror combo.
