Motor mock up
Discussion in '1989-1995 Build-Up/Project Threads' started by Cory Ollendick, Sep 28, 2023.
  1. Cory Ollendick
    Cory Ollendick Member
    Cab is cut motor is mocked up ... ordering parts so can see where things line up if I need to go up down back etc...also as it sits ...stock hood fits ...that's the main goal here
    Erwin Merida and Ponyryd like this.
  2. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    I was going to ask how one goes about the rad support when doing a body drop, but this image shows that you chop and drop it as well. Now I know!
    Cory Ollendick likes this.
  3. aduarte
    aduarte Member
    Avondale AZ
    1990 Toyota Base Model 2 wheel drive
    Those are nice tubular A arms you have on your build. I am looking to get a set of those for my truck when I do my coil over setup. I saw the ones from Stab Fab that has a lot of adjustability. Yours are more of the style that I am looking for.
  4. Cory Ollendick
    After the body drop ...hang the fenders n core support.. Where it naturally wants to lay is the correct drop on it
    Erwin Merida likes this.
  5. Cory Ollendick
    This the Cando setup ...1500
    TRUCK ACTION likes this.
  6. aduarte
    aduarte Member
    Avondale AZ
    Nice. Your build is coming along great.
  7. Cory Ollendick
    Rebuilding the hubs currently with timken bearings... then hopefully doing a wilwood brake setup front n back
  8. aduarte
    aduarte Member
    Avondale AZ
    Wilwood brakes on both front and rear will really enhance your braking performance not to mention looking killer on your build. On my other hot rod project, I have both Wilwoods and Strange Engineering brakes. No complaints with them.
  9. Cory Ollendick
    I like the strange kit ...never seen them til now ... Wonder what setup would work
  10. aduarte
    aduarte Member
    Avondale AZ
    They are pretty much the same as Wilwood as far as braking performance and quality product. I just used Strange for my project since it was available at the time I was building my other project that was not a Toyota.
  11. Cory Ollendick
    They make a supra kit ...I'm curious if it would work now haha
  12. aduarte
    aduarte Member
    Avondale AZ
    If it is worth taking a look at, I would keep all options open and you can then decide what will work best for your build plans as far as cost and simplicity.
  13. TRUCK ACTION
    See my post on disk brakes!
  14. aduarte
    aduarte Member
    Avondale AZ
    Ok. I will research it. Thank you for the info.
