Will these wheels fit?
Discussion in 'Suspension/Chassis' started by dawnsy, Sep 15, 2023.
  1. dawnsy
    dawnsy Newbie
    Im not worried if I rub a little bit just wondering if its too wide. I'm gonna run some pretty small tires just wana make sure they're good before I pull the trigger. worried about the offset mostly. https://www.kseriesparts.com/ENK-3796706530SP.html
  2. dawnsy
    dawnsy Newbie
    I'm 3 inches lowered btw hoping to go more once I get off the stocks.
  3. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    I haven't messed with later trucks but that seems like a super safe set-up. Probably wouldn't give the look you may be going for. Use the search feature to find others rides and specs.
  4. jetas
    Those should fit just fine. Go to willtheyfit.com put in some #s and see what comes up compared to what you have now
  5. dawnsy
    dawnsy Newbie
    thanks bro. appreciate you
  6. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    7" wide tires.. 30 offset.. yeah your almost running OEM width and back spacing. Will they fit will tell you. Idk if your going to stretch tires but you can even go as wide as 215 nd be good lock to lock np.
  7. dawnsy
    dawnsy Newbie
    hmm making me second guess. I hate how skinny the oems are i want something a lil wider.
  8. dawnsy
    dawnsy Newbie
    it says 1.4 mm more poke and 49 mm more inner. thats kinda a big difference from oem, no?
  9. Erwin Merida
    Well there where 14" and 15" wheels, the taller one being 7" wide... but I just checked and the offsets are around +20, so that's why you see the inside being closer to the rails/shock. Also, 49 mm is just under 2" deeper so you should still have room. Turn your wheel now and see if you can add 2" of real estate under that fender!
  10. Erwin Merida
    So this is what you should've got going from sr5 15"x7 vs the enkei you linked with same width tire.. Screenshot_20230916-042346~2.png
  11. jetas
    At the very least go with 18x8 +30 for a nice fit. On either 225/40 for a square look or a 215/40 for slight stretch.
    if you're set on 17, do atleast x8 +30 also.
  12. dawnsy
    dawnsy Newbie
    You feel like 16s arent good? I feel like my wheel well is already pretty close on the top yet my body is so far off the ground. I feel like i need to get smaller wheels than 17 so the frame can sit lower. Maybe im wrong i dont know im new to all this stuff
  13. dawnsy
    dawnsy Newbie
    Thank you for all this assistance bro. But my tires are 205/75 and I believe my rims are 14"? i thought stock is 14. my tires say theyre for 14s atleast. I have a single cab 22RE
    Erwin Merida likes this.
  14. Ponyryd
    Ponyryd Enthusiast
    Yeah a stock rwd stripper truck will have 14s, probably 14x6, he posted SR5, which is a higher trim level and probably has 15s. For the record, my truck is running 15x8.5 with around 0 offset and a 205/60/15, not much help since it’s way off your specs, but here’s a photo for reference.
  15. dawnsy
    dawnsy Newbie
    wow that thing is beautiful bro. im tryna be like you one day too bad my shit is beat up :lol:
    Ponyryd likes this.
  16. dawnsy
    dawnsy Newbie
    Idk if i wana go the steelie type route or more jdm wheels like the rpf1s. I really like some poke but I just cant decide
  17. jetas
    Its whatever you want. 16's will look good with a nice fatty of a tire.
  18. Ponyryd
    Ponyryd Enthusiast
    JDM style is historically running a small diameter wide wheel with some stretch, that’s why I chose the setup I have over a bigger diameter wheel. To me an actual JDM wheel would be perfect (Watanabe, Work, SSR, TE37v, etc…) but there’s very little in my area for used, and I won’t pay $4k+ for wheels on a driver, lol, this bitch sits outside all day, sometimes on the street.
    I have seen steelies look pretty good on minis, and if you take some time looking you’ll find there may be a setup you like in the wheel forum https://toyotaminis.com/forum/forums/wheels-tires.70/
  19. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Hmmmmm....
    Something to think about. I'm looking for 16" wheels. Was planning on buying a set of BBS RS wheels but I may have to rethink that considering your comments. Especially because damn neighbors' cats are always "marking" my wheels...
    Ponyryd likes this.
