L43 to W50 swap: Front parking brake cable length
Discussion in 'Engine/Drivetrain' started by blackmedal1942, Aug 14, 2023.
  1. blackmedal1942
    blackmedal1942 Member
    WA
    1978 Toyota Galavan
    I recently completed an L43 to W50 transmission swap on a 78, and had to move the tranny crossmember 2-3 inches towards the rear of the vehicle in the process. Now, I'm not comfortable with how tight the front parking brake cable is as it comes out of the firewall and wraps downward towards the crossmember.
    Has anybody dealt with a similar situation, and if so what was your solution? Is there another year's parking brake cable that's a bit longer that I can swap in?
    Can you shorten the bracket? Or loosen the cable?
  3. blackmedal1942
    WA
    1978 Toyota Galavan
    Yeah I've tried both but it's unsafe with how tight it is and where it's resting. The rear cables are too long with the shift too but I was able to fix that.
  4. jetas
    I have the front cable from a 79-83 truck, not sure if its longer but if you're interested let me know
    blackmedal1942 likes this.
  5. blackmedal1942
    WA
    1978 Toyota Galavan
    If it's out of the truck do you mind measuring it? There are a bunch on RockAuto for the gen so not sure which one you have. Thanks.
  6. 83pickup
    83pickup Enthusiast
    Phoenix, AZ
    1983 22R Long Bed 5-Speed
    Would a short box or long box affect the cable length? I'd imagine since the frame sizes and thus axle lengths from the cab would be different. Unless I'm wrong :thinking:
  7. jetas
    Doubt it, engine and trans didnt change location, difference happens after the trans x-member
    83pickup likes this.
  8. blackmedal1942
    WA
    1978 Toyota Galavan
    Yeah, spot on.
    Is the one from your 79-83 still in a donor truck or is it laying around? If it's laying around, can you measure it?
  9. jetas
    Im out of town right now but i'll measure it and post when I'm able to.
  10. 83pickup
    83pickup Enthusiast
    Phoenix, AZ
    I see, that makes more sense since the transmission wouldn't be stretched :duh:
