Horn Relay on '87 Xtra Cab
Discussion in 'Maintenance/Repair' started by Mark Horn, Mar 18, 2023.
  1. Mark Horn
    Mark Horn Newbie
    Where the heck is the horn relay on this model? I've checked under the hood (fuse is ok), and under the left side (drivers) kick panel and can't find it. Amazingly YouTube has not been helpful either.
    Thanks in advance,
  2. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    I have a 1988 single cab and the factory service manual which should be the same as 1987. The FSM shows there is no relay for the horn.
  3. MrDinkleman
    MrDinkleman Addict
    SoCal
    From 1988 FSM
    Mark Horn likes this.
  4. Mark Horn
    Mark Horn Newbie
    Thanks, guess I need to order a FSM for this project.
  5. jetas
    What's the issue you're having?
  6. Mark Horn
    Mark Horn Newbie
    Horn doesn’t work. Checked the horn itself and it works. Thought checking the relay would be quicker than taking the steering column apart to check the connection. Guess I’m pulling the steering wheel and column apart.
  7. jetas
    Start with just the horn button. Could just be corrosion on the contacts themselves
  8. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
    Its probably the contact spring that's worn out and its not rubbing with the other contact on the steering wheel. I believe they are brass and get worn out due to that fact that its rubbing or should be rubbing in order to work. pulling the steering wheel off you should see if in fact its that. hope this helps
