1975 distributor
Discussion in 'Interior/Electronics' started by Tom Chitwood, Nov 29, 2022.
  1. Tom Chitwood
    Tom Chitwood Member
    Pine Knot KY
    1975 Hilux
    Hello,
    I have a 1975, 20R, truck. The wiring harness is fried. I will be rewiring the whole truck. I am looking to swap my points ignition system with an electronic system from a 78. I was told the 1975 distributor was a one year thing, and only a 1975 distributor will bolt to a 1975 head.
    I hope this is not the case............Thoughts?
  2. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    I've never heard that the 1975 distributor is unique nor have I ever worked on one but I believe you can just swap the guts. I swapped the guts from a 1979 electronic distributor into a unknown year 18RG distributor. I wanted the correct pick up, reluctor, and connector to plug into my ignition wiring in my 1979 Celica. From what I could see, everything about the guts were identical/interchangeable except for the advance weights which i assume were different to create a different advance curve.
  3. Tom Chitwood
    Tom Chitwood Member
    Pine Knot KY
    1975 Hilux
    Thanks for the reply. I just bought an electronic distributor for 35.00, I was going to risk it. The ad said 75+ distributor. You confirmed my thoughts, Thanks
  4. fred heath
    Don’t forget you’ll need a coil with ignitor to use with that factory electronic distributor. A new ignitor can run $250.00 if you can find one.
    You might want to consider a complete aftermarket ignition system. If you have deep pockets, DUI corporation makes a high end HEI setup.
    Tom Chitwood likes this.
  5. jetas
    MSD style ignition box and stock coil will work well.
  6. Tom Chitwood
    Tom Chitwood Member
    Pine Knot KY
    1975 Hilux
    The distributor I ordered looks like it has 2 vacuum canister/ lines. Why 2? Do I need to hook both up to vacuum, or plug one?
    jetas likes this.
  7. jetas
    Pretty sure you can just use the top one and cap the other one
  8. Tom Chitwood
    Tom Chitwood Member
    Pine Knot KY
    1975 Hilux
    The "new" distributor bolted up nicely. Working on making a new wiring harness for the entire truck now. Shouldn't be too bad, I like wiring.
  9. Tom Chitwood
    Tom Chitwood Member
    Pine Knot KY
    1975 Hilux
    I'm about 80% done with the wring harness, but the distributor I ordered was listed as a 1975+. The distributor bolted up perfectly, and I ordered a 79 cap and rotor. The 79 cap and rotor were too small. It uses the bolt on cap, which is what I ordered. There are no numbers on the distributor, but it bolts to my 1975 motor. Going from points to electronic. What part number do I need for the cap and rotor?
  10. MrDinkleman
    MrDinkleman Addict
    SoCal
    Maybe they sent you a cap and rotor for a T-series (found in Corollas in the US) engine?
  11. Tom Chitwood
    Tom Chitwood Member
    Pine Knot KY
    1975 Hilux
    The larger distributor cap I needed is Advance Auto part number CAC1318. Rotor button DAA1151. Pick up coil MEA2318. Plugs Autolight 64.
  12. Smokewagon
    Smokewagon Member
    Oceanside, Ca
    1975 Hilux RN28
    I have a 75 (from a 20R) distributor if you want it. Sounds like you may have it sorted though.
  13. Tom Chitwood
    Tom Chitwood Member
    Pine Knot KY
    1975 Hilux
    Thanks Man, Got it sorted. Still doing wiring, down to the lights, then fuel system.
