1980 Aftermarket CD player install and positioning
Discussion in 'Interior/Electronics' started by eurofreak2002, Jan 17, 2014.
  1. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    So I throwing this out there to see how you guys have installed or where you put your aftermarket CD players in the 76-83toyotas
    I have an 80 the only place I can really see to do it without hacking the dash up and customizing the stock location is to install under glove box or under the lower factory gauges either way kinda out of the way so give me some ideas and insight!!
    Thanks guys
  2. yota4life
    Put it in the glove box?
  3. tintin
    tintin Enthusiast
    Waikato (NZ)
    80 s/cab 4x4
    it can be done
    it is RHD though
  4. standardbyker88
    My 78 has a different dash but a CD player is just a little too tall and too deep for above the heater where stock is. So on mine I modified a 98 s10 console. Cut it off at the shifter and built a new front that has the CD player angling down in front of the shifter. Works great. Room for some toggles under the deck to for other wiring I've added. Ill dig up pics.
  5. rafafifa
    rafafifa Newbie
    hey buddy where did you get this picture? im trying to make fit it mine but i guess the metal frame has to be cutted out to make it fit right.
    if you can share more pics of this one i guess its the same work lhd and rhd
    cheers
