1995 Tacoma Bed / 1994 Pickup
Discussion in 'Exterior/Body' started by Roland Deschain, Nov 17, 2021.
  1. Roland Deschain
    Roland Deschain Enthusiast
    258607017_702691060717486_6144621961433793767_n.jpg So I've been looking for a bed for some time now and not had much luck. Tonight a bed for a 1995 Tacoma came up for sale locally. Anyone know if it will fit the 1994 frame and will the body lines match up? If anyone knows for sure I'd really appreciate the help.
  2. Roland Deschain
    Well gas door is on the opposite side.
  3. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    cut/weld to the passenger side
    Roland Deschain likes this.
  4. Roland Deschain
    Yeah that’s certainly an option but if the body lines are really off I guess I’ll keep looking.
  5. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    I take it you didn't go with this option.. it's a nice straight bed but, the dip line that runs from front to back would just throw the whole side off. The top seams to line up but then that curve over the wheel well again doesn't add up to the 'squareness' our trucks still hold. IMHO
  6. Perkolator
    Placer County
    1975 Hilux
    Was able to find an example of the Tacoma bed swap onto an 89-95 pickup.
    The pics really suck, but this build over on yotatech shows an idea of what it would look like. What you might want to see is that the OP used a bolt-on aftermarket fuel door to resolve the fuel door on the wrong side issue.: https://www.yotatech.com/forums/f199/whelan709s-1993-pickup-dlx-build-up-thread-250411/
    I know I've seen more, but now I want to say most of those were Tacoma fiberglass bed and front end swaps onto the previous pickup cab -- which was more common for desert prerunner builds.
    Erwin Merida and Roland Deschain like this.
  7. Roland Deschain
    That filler neck deal is slick, I’m about convinced I’m going to end up using a Tacoma bed and that mod would take care of the filler neck issue. Curious about how it mounts. Off to see if I can find out. Thanks for the responses guys.
  8. Perkolator
    Placer County
    1975 Hilux
    As long as you're matching up the bed from a single cab to single cab, or xcab to xcab, I don't think you'll have issue. If you go from xcab to single cab, the mounts may not line up -- but I'm just guessing. Mounts shouldn't be that hard to move if you're determined
  9. Roland Deschain
    Anyone here strong in photoshop? If I could put the bed on and see it maybe I’d put the idea to rest.
  10. Erwin Merida
    That neck filler housing idea is great for a lot of applications! Neat. And now that you put them side by side, I think it would look great! If the mounts line up, go for it!
  11. Roland Deschain
    Yep I think I’ve convinced myself. Now to see how much I can buy a bed for. Has to be much easier than finding one for the 94 and earlier. This a pic online of a standard 1995 Tacoma, it looks just like the two wheel drive bed that was for sale locally. F8FDF281-5A09-453A-AFAE-0B27001D20B1.jpeg
  12. Perkolator
    Placer County
    1975 Hilux
    Not a full bed, but here's another one: [​IMG] [​IMG]
    I believe the thread said the Tacoma's bed mounts do not line up and require relocation to get them to bolt up.
    Where are you located?
  13. Roland Deschain
    North Carolina
  14. Roland Deschain
    B81921A4-104D-4E66-B413-3301B96DAD89.jpeg AC8F576D-DDFE-429C-A666-06638F9FC8FC.jpeg AC2C172C-711D-47BC-A413-1DD2E3C0DEA0.jpeg
    These are pics from the thread mentioned above.
    Erwin Merida likes this.
  15. Perkolator
    Placer County
    1975 Hilux
  16. Roland Deschain
    Got this one off a 1995 Tacoma in the neighboring county. C66BA3BB-64FB-48E1-A0B2-F4D9522E563D.jpeg EAF36BBA-CA5B-4DF8-B3E8-BF66A5AC08B5.jpeg
    Erwin Merida and Perkolator like this.
  17. Roland Deschain
    Removed the fuel filler door, have to make a patch to cover the opening. 421AC649-0D7D-463D-913A-FD026AB38C97.jpeg
  18. Erwin Merida
    That's a good come up! Decent bed panels.
  19. Roland Deschain
    Hope it works going to try to make a patch and weld it in tomorrow and cut the opening on the passenger side.
  20. Roland Deschain
