Diesel Engine Swap Compatibility Question
Discussion in 'Engine/Drivetrain' started by Wayward Boatman, Jun 4, 2021.
Tags:
  1. Wayward Boatman
    Wayward Boatman Newbie
    I am the new owner of a 1983 Toyota Pickup 2WD, DLX, LN40, L Diesel (2.2), w/ 5-Speed Standard Transmission. It appears the current engine will need a major overhaul. It has bad compression in one cylinder, injector pump needs replacement, head gasket leaks, etc. The technician I am working with indicates he can purchase and import a new engine for replacement (but he's not sure about compatibility with different models). I am considering taking advantage of this opportunity to upgrade to a later model, like a 2L, 2L-II, 2LT, etc . (My tech has warned of compatibility issues with a 2LTE).
    My question is: would any one, or all, of the above engines make for a simple and easy swap?
    Any guidance or suggestions will be appreciated.
  2. Liquidhandwash
    Liquidhandwash Enthusiast
    Northen VIC
    1980 diesel
    I've got the same model, they are a straight bolt-in but, depends on what your import engine came out of. You will likely have to change the sump and oil pickup. Some have the intake in a different place and if it's a turbo the exhaust will have to be changed too. the 2LTE has an electronic pump, but you will be able to change it to a mechanical pump quite easly. The only other issue you may run into is the alternator may be different and the glow plugs are a different voltage.
    Erwin Merida likes this.
  3. Wayward Boatman
    This is very good and useful information. Thank you.
  4. Wayward Boatman
    I posted this thread on four different forums (two places on one forum). I’ve received a few responses. Folks concur that any one of the later models (even up to a 5L) should swap in easily. The truck was engineered for an L. I don’t think it wise to push the power beyond the original engineering too far. I think I’ll steer clear of turbo options. A couple folks lit upon the 2LTE (negatively) ---even though I expressed I don’t want that one. One reason I love this little rig is it is all analogue and manual. Simple. ---Nothing automatic, and no computerized components.
    I drove an ’83 Toyota F60 Cruiser (petrol) for 25 years before she finally buckled underneath me (although I believe it is still trundling around in the forests of Mendicino County). I swore next time around I’d do it right with a diesel ---just makes sense.
    I’m going to proceed and start shopping for a 3L.
    I just wish somebody would post and confirm they’d actually done the swap or seen it done first hand.
    Thanks for any input.
  5. sirdeuce
    sirdeuce Veteran
    '86 4Runner and '89 2WD
    Toyota 20/22R and the 4 banger diesels are a simple swap, engines anyway. If you want an awesome diesel, and don't mind a bit of work and money, Cummins has a 4 cylinder available.
    I'm a petrolhead, but I have considered that Cummins for my 4X4.
  6. Liquidhandwash
    Northen VIC
    1980 diesel
    Thanks for any input.[/QUOTE]
    Yes, I've done that conversion but on a 93 Hilux, I pulled out the 22R engine and put a 5LE 3L into it. If you have all the parts required it is a straight bolt in.
    I also own a 1980 Hilux with a factory L engine which is a 2.2L that's it in the picture with the funky headlights.
  7. Wayward Boatman
    Thank you Liquidhandwash.
