emissions crap on a efi
Discussion in 'Engine/Drivetrain' started by burnzya, Mar 17, 2009.
  1. burnzya
    can i remove all the emissions crap on the efi motor? i don't have emissions where i'm at, so if i can i'm going to.
  2. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    you can.
    tho i dont know squat about efi, and the most likely place to find the info is
    www.pirate4x4.com
    i bet its there, if you find it post a link, ill read it and pretend like im learning about efi. :ROFL:
  3. TRUCK ACTION
    You can if no smog checks,but I wouldn't recommend it. The EFI engine depends on all that stuff to run correctly!:cool:
  4. Toyo Trucker
    Toyo Trucker Addict
    Ha ha! Your dream has been crushed.
  5. 88Sandshark
    88Sandshark Toyotaholic
    Lake Elsinore, CA
    Swap the RE for a heavily modded carbed 22R. If we didn't have that crap here in Cali, I probably would try that myself. As TRUCK ACTION said, the EFI depends on that stuff.
  6. burnzya
    i checked pirate. a bunch of people have done it and says it works fine so long as you don't have emissions. one guy said his runs a little funny.
  7. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Gas milage might get screwed....... has the potential to run funny... but nothing serious should happen. Possibly a check engine light.
  8. SD YOTA
    i hear a standalone system will cut all the useless stuff out (smog stuff) and make everything run better, more efficiently. keep in mind this is all computer controlled so if you cut one thing out its gonna fault a code and try to make up for the fault in the system in one way or another.
    mainly...... if yer not gonna run a standalone system, i would be mainly concerned of how lean or rich the motor will run. in that case you will want a wideband and a way to adjust your fuel mix....... piggyback possibly.
  9. IronNam
    +1 ^ Win
  10. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
    my homie took out all the efi emission, blocked off everything and it works fine. he said he feels the performace without the drag anymore.
  11. JOE_1985
    JOE_1985 Veteran
    87 custom
    my 85 celica has the egr removed completely and last hwy trip i got 33mpg hwy, i also have some other gas helping items as well
  12. tuckman
    tuckman Newbie
    Alberta, Canada
    86 xcab 2wd RN55 22RE
    Please elaborate more on the "other gas helping items"
    I have no emissions to worry about either
  13. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Heres what I got from LCEngineering....
    I am doing a 22RE (87 truck)rebuild and was interested in your egr block off plates. What are the pros and cons of removing egr and emissions stuff? Just wanted to know what the pros and cons are when removing egr? Some tell me to remove it and some tell me dont mess with it. I just want a cleaner engine bay after my rebuild. No emissions test where I live so Im not concerned with passing any test.
    (LCE replied)
    The engine does not need the EGR valve to operated so the main issue is the ECU. on some applications it will show a check engine light and on some it won't You can "test" it by bypassing the sensors that attach to the valve. If you don't get any issues then you can remove it with no problems.
    When you say bypass the sensors, do you mean just disconnect it or do I have to rewire anything?
    (LCE replied)
    Bypass the vacuum routing by plugging to lines and disconnect the sensors connected to the EGR valve.
  14. TRUCK ACTION
    Coming back from Danger Zone,got 31 mpg,that's with a smog legal LC Engineering Pro Street EFI. Cruising @ 65!:cool:
