Help.. clutch release bearing
Discussion in '1984-1988 Build-Up/Project Threads' started by sandman808, Mar 28, 2021.
  1. sandman808
    sandman808 Newbie
    smokey point
    1980 hilux
    I don’t have a press. How to R&R bearing from carrier?
    The throw out bearing just slides off the input shaft of the tranny
  3. sandman808
    sandman808 Newbie
    smokey point
    1980 hilux
  4. sandman808
    sandman808 Newbie
    smokey point
    1980 hilux
  5. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    It's a pretty tight fit a press is your best bet. Maybe find a shop that can knock it out while you wait.
  6. jetas
    Aaah shit yes. Definitely need it pressed out. Do you have access to a bench vice? Can try to make that work
  7. Liquidhandwash
    Liquidhandwash Enthusiast
    Northen VIC
    1980 diesel
    They are not that tight that you need a press, you can use a brass drift to knock the carrier off the bearing and it will tap back on again with a hammer
    Toyotashack and sandman808 like this.
  8. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Mine was seized up. It took a good bit before it let go.
  9. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    I'd just get a whole new assembled unit.. easier, time/headache saver. Aren't they like $30?
    Toyotashack and Perkolator like this.
