How to lift a 78 2wd ??
Discussion in 'Suspension/Chassis' started by speede, Mar 2, 2021.
  1. speede
    speede Member
    I'm looking to see if anyone out there has lifted the front end on a 78 2wd drive woth out having to add a stright axle,Or if anyone can give some advice on how they think I should do it I got the rear suspension done already. all I need is a front done. The truck was lowered by them cutting the coils. I want to lifted it a lil. More then the stock height. Thanks for your feed back!
  2. speede
    speede Member
    Erwin Merida likes this.
  3. speede
    speede Member
    Heres the rear end work I got done ✔
  4. jetas
    Could always space the front subframe from the chassis. Will require modding the steering/wiring/hoses but getting creative with it may simplify it a little
    speede likes this.
  5. speede
    speede Member
    After giving it some thought im thinking im gonna have to go with a taller coil spring if I could find one! The stock coil is about 12-13inchs tall & 4 1/2 wide if not mybe find some one who could weld up some brackets to put a coil over?
  6. jetas
    Travel is going to be your biggest factor, you may be able to get a couple of inches over stock height and then you're maxing out the suspension. You will have to find a way to get more lift than that, easiest thing i can imagine is spacing the subframe and having a drop pitman arm made
  7. speede
    speede Member
    Jetas! Your right ✅ im good with just a few inches over stock thats all I need. I would like to level the front with the back.
  8. jetas
    Guna be some trial and error
  9. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    How much lift are you wanting? Coil spacers not an option? Still might max out the suspension/steering if you go more than like an inch
    Regarding a subrame lift -- aren't the engine mounts part of the subframe on these trucks? How would you deal with that other than relocating the mounts to the frame?
  10. jetas
    Drop the trans mount
  11. Perkolator
    Placer County
    1975 Hilux
    You think everything engine-wise would clearance everything? Exhaust and alternator would be pretty damn close to the frame I'd imagine. Also would have to switch to electric fan I guess.
    I dunno if a longer coil or spacer would work really - on my truck there's not much down-travel left in the suspension before the bottom of the ball joint area hits the bump stop protrusion. Wanna say the tire only drops like maybe 1-2" when I jack it up. For compression, I've got a solid 4"+ before the bump stop would touch.
  12. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    "Subframe"?
    Not sure what everyone means by a subframe. These trucks all have a ladder frame to which the engine crossmember is bolted on.
    Why not use a body lift kit after restoring stock front ride height?
    jetas likes this.
  13. jetas
    I call it a subframe because its more than just a crossmember considering it contains the front suspension.
    Perkolator likes this.
  14. MrDinkleman
    MrDinkleman Addict
    SoCal
  15. 4lo4fun
    4lo4fun Enthusiast
    Layton, UT
    78 hilux
    How was the rear lowered?
    I have a set of stock springs in selling.
