Somg Time Again
Discussion in 'Maintenance/Repair' started by TRUCK ACTION, Feb 23, 2021.
  1. TRUCK ACTION
    Has the title reads , is that time once again.
    Took the truck for a 100 mile run yesterday morning , cruised her at 80 the whole way, than straight into the shop. Good to go for another two years!!
  2. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    ehh, that reminds me I've got until the end of next month to do mine. One reason I bought the 75!
    Is the high speed trip the trick to passing with better numbers?
  3. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    If you have a '75, your truck should be exempt from smog check...
  4. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    You still running a Cat? I bought a high flow cat for my 5th gen and was told to do the same thing before heading into the smog station.. still have my doubts about passing tho..
  5. jetas
    Driving the vehicle for a good while at a steady speed gets the cat nice and warm and on newer vehicles gets the monitors reading right so the test goes smooth
  6. Erwin Merida
    Makes total sense.
  7. Erwin Merida
    Any one have success with hi flow cats in emission states such as CA?
  8. MrDinkleman
    MrDinkleman Addict
    SoCal
    CARB is really clamping down on aftermarket parts. You need to find a "lazy" tech who doesn't bother looking under cars. Good luck, though; BAR and CARB coming down hard on techs, with 'undercover cars", etc. Over the years, I've used 6-7 different smog check places all over LA County and they've all been annoyingly careful.
    Any aftermarket parts are going to need a CARB E.O. number. Very few (if any?) high flow cats have them AFAIK. It's the visual inspection that's the PITA. Any shiny new parts will be a red flag to the tech.
    Good luck...
    Erwin Merida likes this.
  9. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    Depends on the smog location and what you mean by 'high flow cat'. If you are in California, you gotta have matching EO numbers.
    I've had many places straight up refuse to smog my truck even before i have a chance to pop the hood. They see an old truck that might fail for this reson of the next, and they don't want that on their record.
  10. jetas
    Just get a bolt in exhaust section made that will be your cat delete. Slap the cat in every 2 years for the test and done
  11. Justin Danger
    Bay Area Peninsula
    Depending on where ya live, that is also a great way to get yer cat stolen
  12. Perkolator
    Placer County
    1975 Hilux
    I have both a 93 and a 75
    My truck has an aftermarket high-flow 2”Magnaflow CAT on it. I put it on when my stock one was stolen off the truck at night, about 15ft away from where I was sleeping - pretty sure they used a Milwaukee cordless hydraulic shears by the look of the cut marks. I guess it’s legal, installed at a shop and I do recall some paperwork regarding CARB stuff for the DMV or whoever
    Anyway, I think I got it back in like 2013 and so far it’s been passing smog. I felt like the numbers were close last time which has me concerned. Also this truck does burn a little bit of oil too
  13. Justin Danger
    Bay Area Peninsula
    I've got the 86 toyota pickup, and a 2012 chevy colorado. The toyota passes with much better margins than the chevy. If things are working right, you should be fine. If ya fail, ya probably have problems worse than a smog check.
  14. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    Catalytic converter thief is on the rise. Don't want to make it any easier to steal. Hoping no one thinks my flex joint is a cat. I know thieves have made the mistake before.
  15. Justin Danger
    Bay Area Peninsula
    I heard an awful racket the other day... neighbor's prius had its cat jacked. Sounded almost as pathetic as the person who stole a prius' cat!
  16. Erwin Merida
    This literally seams to be the easiest, most economical and less time consuming option. I'd hate to get ride of my 2.5" cherry bomb setup!
  17. Erwin Merida
    I've only smogged this particular truck once, nd I had a 'Lazy tech' pass it.. it never had a cat! But Im going to own this thing for a loonngg time, minus well make it pass emissions. Looks like I'm going to have 2 exhaust setups since I'm here in SoCal.
  18. TRUCK ACTION
    Just makes for clean numbers
    Should have fresh oil & filter & fresh plugs also
  19. TRUCK ACTION
    Used to have a LC cat & would change to stock cat when smog time
    Now I just leave the stock on
