1976 Toyota Pickup AKA Blue Magoo
Discussion in '1976-1983 Build-Up/Project Threads' started by Ivey, Jan 14, 2020.
  1. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    77bluyota likes this.
  2. 77bluyota
    77bluyota Member
    Salem Oregon
    1977 Toyota RN23 Shortbed
  3. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    They looked pretty close to my 76 but I can't be 100% sure because I haven't actually gotten around to installing them yet.
  4. 77bluyota
    77bluyota Member
    Salem Oregon
    Excellent, BTW I love the blue of your 23 such a good look
    Ivey likes this.
  5. nottoshabi
    nottoshabi Enthusiast
    This link is no longer available. What are they called? Have you ordered from that place before?
  6. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    nottoshabi likes this.
  7. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Ordered a set of 3” blocks for the rear. Planning to cut the front springs until I figure out what I like then buy new struts and springs.
  8. nottoshabi
    I did the same with mine the first time around, bought mighty max springs and shorter struts. The struts were good but the springs were to soft ended going back to the stock springs and cutting 2 coils out of it. I did get shorter leaf springs and used a 2' block with a shorter shock and that was good. I do actually use the truck for loading it up with weight and the back held up fine.
    Ivey likes this.
  9. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    What front struts did you end up going with?
  10. nottoshabi
    Ivey likes this.
  11. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Headers installed.
    jetas and 77bluyota like this.
  12. jetas
    I forgot about having to flip that bolt on the steering box. The open header is LOUD
    Ivey likes this.
  13. Pearce
    Pearce Toyotaholic
    Washington
    1973 hilux
    I remember running mine fully open. Got some nice flames out of her. But man did it sound like a tractor. Lol
    jetas and Ivey like this.
  14. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    My set of drop blocks arrived. 3” drop with a 3 degree pinion angle correction. They are beefy and the welds look pretty good.
    Do I need to make any other modifications to the rear? Shorter struts or pull a leaf from the spring pack? 4D13C087-666D-4A57-8589-62CCFE11CF3D.jpeg
  15. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Where did you get the blocks? I've been looking for a set... TIA
  16. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    eBay, they were 67 bucks from chassis_tech. Probably take a shot at installing them next week.
    Perkolator likes this.
  17. jetas
    Pull a leaf if you want a 4"+ drop. Shorter shocks shouldnt be necessary out back
    Ivey likes this.
  18. Ivey
    Ivey Veteran
    Portland, OR
    1976 Toyota Hilux
    Alright cool and then on the fronts I was planning to trim the springs down 1.5-2 loops to give me 3 in drop. Will I need new struts for the front right away or can I get away with whatever is in there for a while? Also I’ll probably need to trim or remove the front bump stop yeah?
  19. jetas
    Pull the front bump stop and bracket. Cut like half a turn at a time til you like where it sits. And the shocks will be more and more compressed depending how low you go. Eventually wont matter if the shock is new or old
    RN23CB and Ivey like this.
  20. RN23CB
    RN23CB Member
    Nice truck. I like that blue/white combo with old school tires!
    Ivey likes this.
