22re Boggs down backfire and die. Gas pedal depressed
Discussion in 'Maintenance/Repair' started by Muttley81, Jun 24, 2020.
  1. Muttley81
    Muttley81 Newbie
    Good day, like the title says with gas pedal pressed engine sputters, back fires and die. 1991 22re 5peed base
    Engine starts and run fine tho at idle. Components replaced fuel pump, fuel filter, fuel pressure regulator spark plug, plugs , cap and rotor, and tps, verified compression set timing 5ish degree lost don’t know what to do injectors maybe ecu ???? Any help is good thank u in advance
    Check the TPS?
  3. Muttley81
    Muttley81 Newbie
    replaced the tps sensor same symptoms thinking about readjusting it again
  4. jetas
    Did this start before or after changing those parts?
  5. Muttley81
    Muttley81 Newbie
    Before changing all the parts I bought the truck like this so I have no prior history of it thought it just needed a tune up
  6. Liquidhandwash
    Liquidhandwash Enthusiast
    Northen VIC
    1980 diesel
    Have a look at the airflow meter, if it has a flap-type AFM a backfire can damage them, the flap should not bind if you push it open with your finger
  7. macawilial
    macawilial Veteran
    Born and raised in San Diego
    This and that it should be level for it to work properly
  8. macawilial
    macawilial Veteran
    Also, a disconnected airflow meter would have this symptom
  9. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    it runs at idle, but how does it run? is timing set?
    An engine needs Fuel, Air, and Spark. Those are usually the 3 things I check
    So first: Fuel. Do you have good fuel pressure? Are all the injectors firing properly? You can check their firing by turning the engine with an LED hooked up to the pigtail. It should blink when they fire. If it doesn't, flip it around and try again to see if the LED was in backwards.
    Next: Air. Start with the AFM and check it's resistances. Once confirmed that it works, move downstream to the TB and so on. I like to include a valve lash adjustment in this step (its kida air?). Also check for vacuum leaks.
    Lastly: Spark. I check this with my timing light, and just hook it up to each injector wire 1, 2, 3, 4, and crank to see if they are firing.
    Hope this helps, this is usually my process that has been guided by much advice from all the great people on this and other toyota truck forums. Check out http://www.4crawler.com/4x4/CheapTricks/index.shtml for easy and straight forward AFM and TPS reading.
  10. Muttley81
    Muttley81 Newbie
    i swapped a know good mass air flow Sensor I even removed the black plastic cover to see if the flapper was moving with gas pressed I even read it out with a multi meter
  11. Muttley81
    Muttley81 Newbie
    At idle it runs great with no problems it’s only when gas pedal is pressed it back fires and sputters. I’m not sure of fuel pressure I did replace a new fuel pump, fuel filter and fuel pressure regulator. I set timing at 5 degrees like the hood label says thanks for any help
  12. jetas
    What rpm is it idling at
  13. Muttley81
    Muttley81 Newbie
    My model doesn’t have a tachometer
  14. jetas
    Have you let it get up to operating temp Before hitting the gas?
  15. Muttley81
    Muttley81 Newbie
    Yeah it will run all day at idle no problems it’s only when u press the gas it’s starts to back fire and sputters
