1986 back glass
Discussion in 'Exterior/Body' started by Justintheegreat, Jun 17, 2020.
  1. Justintheegreat
    Justintheegreat Member
    Bay Area CA
    1986 Xtra cab
    tried to search but couldn't find it.
    I wanted to swap out my back glass.
    1986 xtra cab.
    Trying to convert from a slider to a solid.
    Any advice or leads?
    Junkyard, craigslist, Hit up a glass shop and maybe they can have one cut for you
    Justintheegreat likes this.
  3. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Did you search for one? I found several in 30 seconds, all around $100. I'd just call up a local auto glass place, they should all be able to get it in solid. The hard to find rear glass is the "butterfly" window
  4. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Hit up like 5 shops and none can get one. Never asked about cutting one.
  5. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Send me that link. Again must fit xtra cab
  6. Perkolator
    Placer County
    1975 Hilux
    All the places I found say it fits 2nd/3rd gen truck cabs, it would be same glass between single and xtra cabs.
    I literally just googled “1986 Toyota pickup rear glass” and looked in the Shopping tab. Links to eBay, glass companies, heck you can even get it from Toyota still. It’s part number 6481189120
  7. jetas
  8. Justintheegreat
    Bay Area CA
    1986 Xtra cab
  9. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    Searching on this site. Looks like the back glass for the standard will not fit my extended cab.
    Extended cab is taller.
    Just from what I've gathered on this forum.
  10. Perkolator
    Placer County
    1975 Hilux
    Huh, would have figured it was the same size glass for sure, weird. Oh well, just go custom and have someone cut it for you since it’s just a gasket holding it in. PO of my Hilux was a glazier and did the solid window himself out of a slightly gray glass
  11. Perkolator
    Placer County
    1975 Hilux
    Dunno why I keep thinking about this, but if the same glass works between the 2nd/3rd gen single-cab trucks, I'd assume the same interchangeability for the extra cab trucks, right? If that's the case, here's one for the 3rd gen in solid: eBay
    Just curious - why solid? I've had both and definitely would prefer it to open
  12. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    in my opinion i just think its a cleaner look. but my old slider is rattling and loose. might just replace if i cant find a solid. dude on Facebook @ Toyota pickup mafia wanted $400 for a solid glass for the extended cab
  13. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    trade ya my solid rear xtra cab window for your wheels (-;
    but yeah, it is flat glass, so any glass shop should be able to cut one for you pretty easily.
  14. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    someone painted my wheels. :duh:
    going to try and strip the paint off and polish the aluminum.
    i have had another ask about my wheels. what do they go for?
    Justin Danger likes this.
  15. Justin Danger
    Bay Area Peninsula
    When I got my turbo pickup I put some american racing outlaw wheels on it, and swapped the turbo wheels onto my broken down old sr5. I listed the sr5 on craigslist and got a lot of people who wanted the wheels, but not the truck. I ended up selling the wheels for $400 to a guy who drove almost 3 hours, and swapped his steelies with the turbo wheels on my old truck. I made $400, but he paid near 6 hours of travel time, the effort to swap the wheels, and the $400.
    They are the most desirable 14" wheels that I have seen.
  16. Justintheegreat
    Bay Area CA
    1986 Xtra cab
  17. Justintheegreat
    Bay Area CA
    1986 Xtra cab
    i ended up finding a solid glass from a guy on instagram fairly cheap. @yodagang_
