74 hilux 3.4 s/c swap
Discussion in 'Pre-1975 Build-Up/Project Threads' started by evan t jenkins, Jun 11, 2020.
  1. evan t jenkins
    evan t jenkins Newbie Premium
    saint george utah
    1974 hilux long bed
    hilux resized 1.jpg so i found a 74 longbed to use as a new shop runaround truck. before i started
    Erwin Merida likes this.
  2. evan t jenkins
    saint george utah
    1974 hilux long bed
  3. evan t jenkins
    saint george utah
    1974 hilux long bed
    Erwin Merida and Perkolator like this.
  4. evan t jenkins
    saint george utah
    1974 hilux long bed
  5. evan t jenkins
    saint george utah
    1974 hilux long bed
    KS.ID likes this.
  6. evan t jenkins
    saint george utah
    1974 hilux long bed
    and carpet going in hilux resized 7.jpg hilux resized 8.jpg hilux resized 7.jpg hilux resized 8.jpg
  7. jetas
    Need more info on the swap! What all did it take to get it fitted and how was the wiring?
  8. evan t jenkins
    saint george utah
    1974 hilux long bed
    fitting was not to bad . i took 2 inches out of the lower crossmember ,and used a rear sump oil pan off a 2wd 3.4 truck . the wireing is the easy part . that is what i do everyday .make 3.4 swap harnesses for the 4x4 crowd
    Jim Thompson likes this.
  9. Markus Vandevender
    Markus Vandevender Member
    Auburn
    1978 Longbed
    once i turned my computer 90 degrees, looks like a really nice swap :lol::lol:
  10. KS.ID
    KS.ID Enthusiast
    Bay Area, CA
    RN22 1972 Hilux
    Awesome on the cluster retrofit. I bought a 76' cluster for the same reason, Temp read out, thought it was plug-n-play.
  11. evan t jenkins
    saint george utah
    1974 hilux long bed
    harness is different on the back , the temp one has 2 pigtails
  12. evan t jenkins
    saint george utah
    1974 hilux long bed
    used the mighty max ft springs . and 3 inch block . to lower it hilux resized 9.jpg hilux resized 9.jpg hilux resized 10.jpg
  13. evan t jenkins
    saint george utah
    1974 hilux long bed
    and finished the harness under the hood hilux resized 12.jpg hilux resized 12.jpg hilux resized 13.jpg
    Baka and Erwin Merida like this.
  14. THorn
    THorn Member
    Portland, OR
    1974 Hilux
    Wow! Amazing fit. A while back, I bought a 74 with a 5VZ already in it, and I have some gripes with some of the p.o.’s efforts to shoehorn it in. I’m really curious, what transmission are you using? Also, did that radiator come with the engine? I see that you still have what looks like the clutch fan and shroud, maybe cut around a customized hose?
  15. evan t jenkins
    saint george utah
    1974 hilux long bed
    stock 3.0 r151 trans out of a 3.0 2wd .with marlin stuff inside . radiator is also a 3.0 90 2wd truck . stock 3.4 upper hose shroud cut to fit
  16. evan t jenkins
    saint george utah
    1974 hilux long bed
    Since then it got a torsen gear locker in the rear , cheater slicks , and skinny tires in front
  17. evan t jenkins
    saint george utah
    1974 hilux long bed
    THorn and Erwin Merida like this.
  18. evan t jenkins
    saint george utah
    1974 hilux long bed
  19. evan t jenkins
    saint george utah
    1974 hilux long bed
  20. evan t jenkins
    saint george utah
    1974 hilux long bed
