77 Utility project
Discussion in '1976-1983 Build-Up/Project Threads' started by Utility 77, Feb 20, 2018.
  1. Utility 77
    Utility 77 Enthusiast
    Oakdale
    1977 Reg Cab w a utility bed
    Have to do the dreaded Cali Smog test....what a bunch of BS....now that I see some get a car threw smog w none of the smog stuff functioning. It this does not work ? Will try to get by w a weber,??? .lol
  2. Utility 77
    Oakdale
    On my, so many !little parts !!!!! Sad this truck was driven for years without the air cleaner on !!!! Go back n see the engine before I cleaned it....This was the dirtiest engine I ever worked on and now this carb ?!? There is lots of silt n dirt in the whole carb ... IMG_20180403_192320.jpg
  3. Utility 77
    Oakdale
  4. Utility 77
    Oakdale
  5. Utility 77
    Oakdale
    It has been soaking for awhile now. Might have a layer of two off by now....lol in the meantime, these just came IMG_20180404_002328.jpg
    jetas likes this.
  6. jetas
    Are those Hilux badges the ones off ebay?
    Utility 77 likes this.
  7. Utility 77
    Oakdale
    Yes they are
  8. Utility 77
    Oakdale
    Well, she starts runs till warm.....then dies ?!? Have to give it half throttle to keep running. Take my foot off accelerator, and dies ?
    how do you check if idle solenoid is working ? Took it out, put power to it, it clicks but do not see anything. Any help here would be great
  9. Hands_On_Henry
    Hands_On_Henry Member
    Michigan
    1985 22R/4spd
    I see you just went through the carb, I'm wondering if the adjustments have been put back to the baseline settings? My truck would do the same before. I think people start adjusting the carbs as they get older to keep them running then when the inevitable carb rebuild happens they need to be turned back.
    Just a theory....Good Luck
  10. jetas
    Hows the quality of the badges?
  11. BeardNomad
    BeardNomad Newbie
    My truck does funky stuff like that with the weather change in my area. Forever adjusting my carb.
  12. Utility 77
    Oakdale
    Plastic, a bit light....Will see how they hold up....look Great tho...
  13. Utility 77
    Oakdale
    put it all back to spec's in book, ran great till warmed up..... Now I have moved them all again and again.....wish I was not in Cali !!!!! Would put the Webber on and be happy
    Hands_On_Henry likes this.
  14. Hands_On_Henry
    Michigan
    1985 22R/4spd
    Me too! Lol. The struggle is real....
    Utility 77 and BeardNomad like this.
  15. Utility 77
    Oakdale
    Well turns out part of the problem was my distributor.... Had the white turn knob under a clear cap. Was all the way unscrewed ?!? I can idle at about 1200 rpm now....but not power ? Next is replacing all vacuum lines I guess
  16. Utility 77
    Oakdale
    Hello everyone, had to park this. Before I blew it up.... Hate this carb ! It has been sitting g all summer, I been out on my motorcycles.... But tomorrow morning the war starts again...... Have a friend coming to help...he has had any of these
  17. Dan McBoost
    Dan McBoost Enthusiast
    NY
    78 Pickup
    ahh the reasons I gave up on the 20R and am doing the 22RE swap.
    good luck though!
