93 4cyl pickup Power Steering Conversion
Discussion in '1989-1995 Pickup Discussion' started by 93Pickup, Feb 1, 2018.
  1. 93Pickup
    93Pickup Newbie
    Anyone with tips/links for adding power steering to my ‘93?
    I’ve found a few references, but the latest is 6 years old.
    Thanks
  2. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
  3. 93Pickup
    93Pickup Newbie
    Thanks!
  4. Perkolator
    Placer County
    1975 Hilux
    Yep good luck.
  5. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
    Best way to go is having a donor truck or a complete junkyard truck you will need the obvious pump brackets hoses ect. Steering bmgearbox but you will also need the steering column for the easiest swap simple unbolt and bolt in
  6. 93Pickup
    93Pickup Newbie
    Thanks
