Idler arm or steering link bad?
Discussion in 'Suspension/Chassis' started by Houa Thao, May 25, 2017.
  1. Houa Thao
    Houa Thao Enthusiast
    Sacramento, ca
    91extracab
    Was replacing the power steering high pressure line and bleeding the fluid. While steering L to R heard a pop turing to R side. Found this.
    Looked like that shit hasnt been greased in a decade if its greaseable
  3. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Looks like the castle nut just needs to be tightened... it shouldn't allow that to pop up like that.
  4. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Unless that stud is broken away from the center link?
    Then, yes, you need a new one.
  5. jetas
    Looking at it again its definitely the idler arm stud. Have someone turn thw wheel back and forth and look under there and see what it does
  6. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    That castle but is still held with the cotter pin where it was installed originally, it's definitely the stud pulling out of its anchor point. So whichever part the stud side is on - the link?
    Good luck extracting it, hopefully it doesn't rip out entirely from the link. Use a jaw puller, not a pickle fork.
  7. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    To me it looks like the boot has scooted up, but other than that it doesn't look like anything is wrong. I get a pop when I turn my wheel all the way to the right because the Idler arm hits the end of my steering dampener.
  8. Houa Thao
    Sacramento, ca
    91extracab
    That's what I think too. Too much gap in there. Heading to autozone for a new one.
  9. Houa Thao
    Sacramento, ca
    91extracab
    Yep. The stud did pop out.
  10. Perkolator
    Placer County
    1975 Hilux
    At least it didn't do it while driving it!
    Last year a friend of mine pulled into a parking spot outside our building with his old 82 2wd pickup. As he made the turn into the space his pitman arm stud popped out of the casting and he was without steering, he got lucky I suppose since it didn't happen on the road. Helped him with a parking lot fix using a ratchet strap and some bailing wire - enough for him to move a few hundred feet to where he could work on it without being hassled by parking enforcement.
  11. Houa Thao
    Sacramento, ca
    91extracab
    All should be good now. Tie rods are a few years old and now steering center link.
